DadoWiz Jig setup question - Router Forums
post #1 of 11 (permalink) Old 05-06-2012, 08:35 AM Thread Starter
First Name: Ralph
Default DadoWiz Jig setup question
I recently acquired a Dado Wiz jig and want to use it. I am looking for Bit recommendations. I have emailed the company at both of their posted addresses - 3 weeks - no response (makes me wonder how they will be if I have an issue). In the instructions - they suggest a down spiral bit. Thatís great, but..... If you have seen the jig, it is pretty thick so the depth of the router has to be set pretty close to max I am guessing.
What I want to know is:
1 - What width would be the best choice - 1/2"?
2 - I can use both 1/4" and 1/2" collet - is one better than the other?
3 - In order to lock securely in the Router and still be able to cut to depth - How long should the bit be?
Any help will be greatly appreciated!!!
BeauxTi is offline
post #2 of 11 (permalink) Old 05-06-2012, 06:54 PM
Exclamation
The width of the dado is governed by the width of the board you want to put into the dado.
This is all I could find:
Infinity Cutting Tools - Precision Router Dado Jig - YouTube
Hard to recommend a product when the sellers do not respond to correspondence.
Sydney, Australia
jw2170 is offline
post #3 of 11 (permalink) Old 05-06-2012, 07:07 PM
Router Accessories
Amazon.com: Dadowiz Precision Dado Fixture By Peachtree woodworking PW549: Home Improvement
post #4 of 11 (permalink) Old 05-06-2012, 10:04 PM
I recently acquired a Dado Wiz jig and want to use it. I am looking for Bit recommendations. I have emailed the company at both of their posted addresses - 3 weeks - no response (makes me wonder how they will be if I have an issue). In the instructions - they suggest a down spiral bit. That’s great, but..... If you have seen the jig, it is pretty thick so the depth of the router has to be set pretty close to max I am guessing.
Quote from Peachtree's listing:
Frustrated with making Dados? Don't hassle with them any longer. The self-calibrating feature is the secret to your new found success in creating the most precise dados you could ever imagine. The Dadowiz™ allows you to make precise dado's each and every time you use it! It comes already calibrated to use 1/4, 3/8, and 1/2 inch router bits (sold separately). The Dado Wiz features a NEW micro-adjust which allows you to calibrate run out of the router bit and router for a perfect fit every time. The Dado Wiz will fit straight edge clamps with a maximum width of 23/16" and a maximum height of 5/8" tall (straight edge clamp sold separately)
John Schaben
jschaben is offline
post #5 of 11 (permalink) Old 05-07-2012, 06:13 AM
First Name: Normand
thrinfo is offline
post #6 of 11 (permalink) Old 05-07-2012, 10:13 AM
boogalee's Avatar
First Name: Al
I have a jig which is similar to the Dado Wiz (Dado Max). Woodline recommends 1/2" shank bit. (2) It is highly recommended that 1/2" diameter shank router bits with an overall length of 2 1/4" are used.)
1 - I use a Whiteside down cut sprial bit with a 1/2" shank, 3/8" cutting diameter, 3" overall length.
2 - I use the 1/2" shank because you would be hard pressed to find a 1/4" bit 3" long.
3 - You could use a bit shorter than 3" but I'm not that brave (longer is better).
The reason that I use a 3/8" cutting diameter bit is most of my dados are with 1/2" and 3/4" plywood.
Woodline 1 800 472 6950 (woodline.com)
Peachtree 1 888 512 9069 (ptusa.com)
This pdf file is the manual from Woodline.
boogalee is offline
post #7 of 11 (permalink) Old 05-07-2012, 10:22 AM
CharleyL's Avatar
First Name: Charley
You don't need this jig.
See my response to the active post "Material to use for jig" in this Jigs and fixtures forum. I tell how to do the same thing with a top bearing mortising bit and two straight edge clamps.
Charley
Central North Carolina
CharleyL is offline
post #8 of 11 (permalink) Old 05-07-2012, 10:26 AM
1 pc 1/4" SH 1-1/2" Extra Long Straight Router Bit | eBay
post #9 of 11 (permalink) Old 05-07-2012, 03:30 PM Thread Starter
First Name: Ralph
already have the jig.
BeauxTi is offline
post #10 of 11 (permalink) Old 05-07-2012, 03:31 PM Thread Starter
First Name: Ralph
Thanks Boogalee!!
BeauxTi is offline
dado jig and proper bit question dask General Routing 9 02-21-2012 01:35 AM
Yet another dovetail jig question drbbob Jigs and Fixtures 1 01-27-2012 09:20 AM
Question On Using Oak Park Spacer Box Jig alittlebit Table-mounted Routing 7 12-18-2011 08:23 AM
HF Dovetail Jig + Router + 3/8ths stocK Question griff017 General Routing 9 09-19-2011 01:41 PM
Oak Park Box Jig question gazippoman Jigs and Fixtures 4 04-08-2009 03:17 AM
