Peachtree Dovetail Jig - Router Forums
post #1 of 7 (permalink) Old 05-08-2012, 02:39 PM Thread Starter
First Name: Doug
Default Peachtree Dovetail Jig
I have a Peachtree dovetail jig that mounts to a user made Mounting Block
I've made two blocks for it (3/4” pine stock glued together) & they both ended up warping over time due to the humidity out in my garage/shop!
It's not that big of a deal to make up another mounting board, But I would like to use a better type of wood that's less pron to warping. Personally I don't like to use MDF when it's going to be out in the garage exposed to any kind of moisture/humidity, I was thinking of maybe trying some quarter sawed oak?
dwall174 is offline
post #2 of 7 (permalink) Old 05-08-2012, 03:23 PM
Hi
Just use MDF and PAINT it , to keep the moisture/humidity out of it.
You can use the item below,with a screw or two ,no glue needed to make your block.
1125 ..3/4" X 4"X 48 " Sheet**
http://www.ptreeusa.com/uhmwproducts.htm
post #3 of 7 (permalink) Old 05-09-2012, 06:33 AM
pretender's Avatar
First Name: Gary
Doug. I have the same type jig and I used Poplar or Tulipwood. It, been on there for over a year and has't changed so can notice and it's affordable. Gary
pretender is offline
post #4 of 7 (permalink) Old 05-10-2012, 05:49 PM
darrink's Avatar
First Name: Darrin
Send a message via Skype™ to darrink
I have the same jig and my mounting block is made of MDF. With a couple of coats of Johnson paste wax, it will last a long time. Or you can paint it as BJ suggest. Mine is over a year old, and is still solid.
Thanks!
Darrin
Sealy, TX
darrink is offline
post #5 of 7 (permalink) Old 05-10-2012, 09:16 PM Thread Starter
First Name: Doug
Thanks for everyone’s replies!
I was in my local Woodcraft store today & they had some Ash table leg stock 2-1/2” X 2-1/2” X 36” that I picked up. It has really straight grain & I can cut it in half then stack the pieces to make the block!
dwall174 is offline
post #6 of 7 (permalink) Old 05-11-2012, 07:44 AM
OPG3's Avatar
First Name: Otis
I second the suggestion of Poplar! It is a wonderful wood for this, but ash is also an excellent choice for a dimensionally stable wood. Pine is never used to make baseball bats - there are several reasons why! I wonder if a pine bat would be better for hitting a curve ball?
OPG3
Tweak everything!
OPG3 is offline
post #7 of 7 (permalink) Old 05-12-2012, 08:25 PM
dutchman 46's Avatar
First Name: Howard
They are very good at Breaking! Pine isn't very stable,in My thinking. Much better at smaller projects, and if the rite kind, 2by 4's
John 3:16
dutchman 46 is offline
EZ Dovetail Jig bobj3 Jigs and Fixtures 12 01-14-2020 07:20 PM
Peachtree 15 inch dovetail jig Noob Jigs and Fixtures 13 12-03-2013 07:37 PM
New Lower Priced Leigh Dovetail Jig scrollwolf Jigs and Fixtures 1 07-08-2007 05:10 PM
