Another Leigh Jig Question - Router Forums
post #1 of 3 (permalink) Old 05-08-2012, 02:57 PM Thread Starter
First Name: Brian
Default Another Leigh Jig Question
I have an older jig (D1258-12) and have been debating with myself on whether to keep it and enjoy my current tool that is mortgage free or to upgrade to the D4R. I recently upgraded some of the parts on my current jig (knobs, scale, etc.) and I ordered the VRS at the same time. The manufacturer told me to just cut the VRS to fit my current jig (12 inches). I have held off on cutting and installing it because I am still unsure whether to spend the big bucks on the D4R and use my VRS with the new jig. Has anyone on this forum used the older Leigh jigs and upgraded to the newer models? Other than getting the advantage of the 24" vs. 12", is there any other advantage or improvements in the jig?
Famineguy is offline
post #2 of 3 (permalink) Old 05-08-2012, 04:50 PM
CharleyL's Avatar
First Name: Charley
I haven't ever used a jig like your's, but I have seen them. The new D4R is quite an upgrade over it. Of course the D4R is wider which will allow you to set up a right and left pattern for cutting the right and left sides of drawers at the same time or make a 24" high box with dovetailed corners. The clamping bars are much stronger, the clamp knobs have been replaced by lever knobs which let you repeat the same clamping pressures for multi piece cuts, the D4R has built-in side stops that can't get out of alignment, and I'm sure there are a few more improvements that I haven't thought of. It's been years since I saw a jig like your's. But the method of cutting dovetails on your jig and the D4R is basically the same. If you have the money and use your dovetail jig a lot it might be a good idea to upgrade. If you use it very little, then maybe the new one isn't such a good idea. It's really your call.
Charley
Central North Carolina
CharleyL is offline
post #3 of 3 (permalink) Old 05-08-2012, 07:55 PM Thread Starter
First Name: Brian
Thanks Charley. This helps. I still have to think about this one.
New Member Leigh FMT question Ronny Jigs and Fixtures 4 06-16-2011 09:20 AM
Incra Hinge Jig Question Ken Bee Jigs and Fixtures 3 06-01-2011 02:18 PM
Oak Park Box Jig question gazippoman Jigs and Fixtures 4 04-08-2009 03:17 AM
All Leigh Jig Owners WillyInAus Jigs and Fixtures 3 07-19-2007 09:27 AM
