Leigh FMT for long work pieces?? - Router Forums
post #1 of 4 (permalink) Old 05-23-2012, 03:46 PM Thread Starter
First Name: Patrick
Default Leigh FMT for long work pieces??
Can the Leigh Pro or Super FMT be used to make tenons on ends of long work pieces, such as bed rails? My bed rail is almos84" long, too tall to standup under the FMT unless I had a very tall shop.
Can the FMT be mounted horizontal to route the tenon?
Is there a better idea?
Thank You!
...Patrick
mackinlay is offline
post #2 of 4 (permalink) Old 05-23-2012, 04:21 PM
JessEm Zip Slot Mortise Mill Loose Tenon Joinery System
Thank You!
...Patrick
Name:	jessem tentons.jpg
post #3 of 4 (permalink) Old 05-23-2012, 07:48 PM
Country: Japan
First Name: singh kuldeep
Send a message via Skype™ to samurai
Thank You!
...Patrick
check out my new hybrid pantorouter.it has no barrier for long piece like leigh.i just develop fastest way to setup template for mortise and tenon.
here is the video fast template setting for hybrid pantorouter - YouTube
samurai is offline
post #4 of 4 (permalink) Old 05-23-2012, 10:00 PM
CharleyL's Avatar
First Name: Charley
I just responded to a similar question on Sawmill Creek.
I once clamped my FMT jig to my neighbor's 2nd floor deck railing (with his permission) to do some tenons on long stock. It went well, but getting the stock properly positioned and clamped while working from behind the FMT was a bit of a trick. The routing portion of the project went well though.
Charley
Central North Carolina
CharleyL is online now
New Member Leigh FMT question Ronny Jigs and Fixtures 4 06-16-2011 09:20 AM
Cut both box joint pieces at once? Fretts Jigs and Fixtures 2 06-15-2010 01:17 PM
Router for leigh super fmt Spruce4 General Routing 6 02-15-2010 03:09 PM
Leigh FMT xpsensation Jigs and Fixtures 8 01-28-2009 04:21 PM
New Lower Priced Leigh Dovetail Jig scrollwolf Jigs and Fixtures 1 07-08-2007 05:10 PM
