Routing without a bushing guide - Router Forums
post #1 of 3 (permalink) Old 05-24-2012, 05:56 PM Thread Starter
First Name: Frank
Smile Routing without a bushing guide
Is ist possible to make a Dovetail Joint with Dovetail Jig and not use a bushing guide on the router? This may have been answered at sometime and I missed it.
Tagwatts1 is offline
post #2 of 3 (permalink) Old 05-24-2012, 08:25 PM
kp91's Avatar
First Name: Doug
Frank,
Some dovetail jigs are designed to be used with bearing guided bits, others using guide bushings.
trying to use a jig designed for a bushing with a bearing guided bit will probably change the geometry of the bit and the joint won't fit.
1 John 1:9
Fredericksburg, VA
kp91 is offline
post #3 of 3 (permalink) Old 05-24-2012, 08:34 PM
Hi Frank
" on the router? " yes if you use the router table to put the dovetails in place.
guide bushing size chart mharwell01 Guide Bushings and Templates 21 08-18-2017 10:37 AM
Guide bushing identification Mike Guide Bushings and Templates 42 09-22-2013 08:25 PM
Guide bushing fabrication johnpaulh Guide Bushings and Templates 10 01-30-2012 06:32 AM
Bit not centered in guide bushing RonH Guide Bushings and Templates 14 05-01-2009 12:41 PM
Router template inlay V Garry General Routing 7 12-27-2008 06:49 PM
