CAD drawings of finger joint jigs - Router Forums
post #1 of 2 (permalink) Old 05-26-2012, 06:34 AM Thread Starter
Country: Denmark
First Name: Torben
Default CAD drawings of finger joint jigs
Looking at the various finger joint jigs available, I think it would be nice to have one. But they are kind of expensive to me, especially when imported.
Given that I have access to a CNC machine and material (6 or 8 mm alu).. is it not possible to find a CAD drawing (either in STEP or DWG or similar) of such jigs ?
After all, it's not rocket science.
Perhaps someone could also enlighten us all on a calculation from "finger width" to width of teeth / holes in the jig ?
I have tried to google this subject but without luck.
myicq is offline
post #2 of 2 (permalink) Old 05-26-2012, 09:08 AM
Ken Bee's Avatar
First Name: Ken
Here are two plans for box joint jigs. I built the top one (2) that is fairly simple to build and use. The number of holes and/or teeth would naturally depend on the width of the board you are cutting the teeth into. I use mostly 1/4 inch teeth and slots, but have never taken the time to calculate the number because it will vary from board to board due to board width. I just cut them, fit the boards together and trim if necessary. At the bottom of each plan it shows how to cut the joints and other pertinent information about box/finger joints.
When something is advertised as being foolproof there is always a better class of fool that comes along to prove them wrong.
Ken Bee is offline
Finger Joint Bit Which one? MarlaS Router Bits - Types and Usage 9 11-07-2011 12:48 PM
finger joint bit for edge to edge atmartin23 Router Bits - Types and Usage 20 09-04-2009 01:51 PM
Got the set of box joint jigs rick112563 Jigs and Fixtures 2 09-11-2008 04:58 PM
My first finger joint box simplenik Table-mounted Routing 6 06-24-2007 08:52 AM
My first ever Finger (box) joint simplenik Table-mounted Routing 19 06-23-2007 09:53 AM
