Simple pin router - Router Forums
post #1 of 6 (permalink) Old 05-28-2012, 12:45 AM Thread Starter
First Name: Chris
Default Simple pin router
Here is my simple pin router. I used some 1x4s iI had laying around and some 30* cutoffs from my wall cleats to put it together.
I can use the drill press table to raise and lower the table to the height I want.
As simple as it is, I think it will be useful.
Thanks for looking.
Chris Curl is offline
post #2 of 6 (permalink) Old 05-28-2012, 10:04 AM
Wood Chip's Avatar
First Name: Gary
Clever! How do you use a pin router? Don't think I've seen one before.
Wood Chip is offline
post #3 of 6 (permalink) Old 05-28-2012, 10:45 AM Thread Starter
First Name: Chris
here is just one example:
Chasson Guitars - Kent Chasson
post #4 of 6 (permalink) Old 06-09-2012, 01:55 AM Thread Starter
First Name: Chris
ok, maybe it is more of an overarm router.
but i was not happy with the way the table rocks back and forth when you crank it up and down, making it very difficult to keep the bit exactly the same distance from the fence.
so here is my new strategy for it ... now i can set the table where i want it, lock it down, and use the router's height adjustment
it is not complete ... this is just a prototype, but i think it is going to work out pretty well.
thanks for looking
post #5 of 6 (permalink) Old 06-09-2012, 09:10 AM
First Name: Duane
Chris, I understand pin routing, but what does this setup do that a router table won't do?
Dmeadows is offline
post #6 of 6 (permalink) Old 06-09-2012, 11:51 PM Thread Starter
First Name: Chris
probably nothing really, but i use my router for grooves more than anything else right now. using a table for those kind of things is the same as doing it blind. with the router oriented like this, i can see what i'm doing.
and i can certainly put a pin in the table top if i want
New Router my way reible General Routing 21 12-08-2018 12:06 PM
Grizzly G1035 Shaper vs Router Table GAVolunteer Table-mounted Routing 11 06-30-2010 07:35 AM
Shopmade pin router? DanSullivan General Routing 4 03-14-2009 03:45 AM
40mm template guide harrysin Guide Bushings and Templates 144 02-22-2009 12:39 PM
