jig for curved door - Router Forums
post #1 of 5 (permalink) Old 05-29-2012, 06:45 AM Thread Starter
First Name: N/a dave
Default jig for curved door
I`m making some quarter circle glazed corner cupboards,and I`m try to make a jig for the mortise &tenon joints on the doors.the door sweeps "2" per cupboard are 6inch 1 1/2 x1inch .I`m thinking if I lay them on there backs I could make a carriage and run it over the router but the inner curved part will catch on the base plate.I know I could just put a screw through the sweep into the door stile but it would look & be wrong.cheers to all Dave
davewilson is offline
post #2 of 5 (permalink) Old 05-29-2012, 01:02 PM
dutchman 46's Avatar
First Name: Howard
Welcome to the forum, Dave! I can't help You with this one, but I am sure that others will Enjoy the forum, and take a look at some of the up-loads. very useful information!
John 3:16
dutchman 46 is offline
post #3 of 5 (permalink) Old 05-30-2012, 09:54 AM
First Name: Art
I'm having a hard time visualizing what you are saying. Could you post a drawing or picture?
mgmine is offline
post #4 of 5 (permalink) Old 06-04-2012, 05:56 AM Thread Starter
Art,hi I`m making some corner cupboards,now if they were flat fronted like a normal door they would have simple m&t joints but these doors are curved so the shoulders on the tenons are splayed ie bigger at the front than the back,If you draw a 13inch quarter circle then 12 1/4 inch one that is the sweep 1 3/4inch from each end is the frame style whats left is the 2 doors so [email protected]/4"sq are the door styles (rebated) for glass you`ll now see the joints I have to cut.I`m thinking a template and a small ring fench then just plunge down and hope cheers anyway art yours dave
post #5 of 5 (permalink) Old 06-04-2012, 07:39 AM
First Name: Art
Dave the tenons are the easy part they should be done with a band saw. The mortise is another problem altogether. You might want to consider an option like this in which case the router would ride on a wedged sled type of platform that would mimic the tenon's angle.
mgmine is offline
First Box Joints w/a Hart Design Jig Wild Rag Jigs and Fixtures 2 03-23-2009 08:54 AM
