DIY MFT top - Router Forums
post #1 of 5 (permalink) Old 06-05-2012, 02:07 AM Thread Starter
Country: Sweden
First Name: Matt
Default DIY MFT top
I made my own version of the Festool MFT some time ago, and thought to share how I did the holes, since that is a question I often get.
The end result, even though it has been modified with an built in Router table since the picture was taken. But that is for another thread.
I got the inspiration using "dogs" from one of the Festool forums. The problem many had was how to make the holes parallel and accurate. Some invented great techniques solving the problem, but I wanted a simpler method. So I came up with this, a square with 25 holes accurately spaced according to the original MFT. With one row modified with 5 counterbored holes. I made 2 kind of "dogs", one set for locking the template when routing and one set of "dogs" for normal work.
A 30 mm copy ring and a 20mm routerbit was ordered
Ring and routerbit in place, the template is carefully aligned with the corner and edges of the MFT top
First hole routed, and perhaps now you can see why the first row has a counterbored hole
First locking "dog" in place and flush with the templates top surface.
First row finished with the 3 locking "dogs". The template sits rock solid!
All the holes are cut
Now, the locking dogs are removed and the template is moved so that the first row of the template is aligned with the last row that was cut. The locking "dogs" secures the template ones again.
Another angle
Done and finished!
This template can of course be made with as many rows and columns as desired. and I wanted it in acrylic. But the company that laser cut this had this 10mm metal plate laying around so I took that instead!
Take care
/Matt
SolidMind
Solidmind is offline
post #2 of 5 (permalink) Old 06-05-2012, 03:04 AM
breezy's Avatar
First Name: Arie
Brilliant idea and great result.
Arie.
breezy is offline
post #3 of 5 (permalink) Old 06-05-2012, 09:53 AM
Guest
First Name: Robert
Default Mft
MFT - don't tell me what that is. I'm having too much fun researching all the possibilities. Topping the list now is Minnesota Federation of Teachers.
57759 is offline
post #4 of 5 (permalink) Old 06-06-2012, 04:10 AM Thread Starter
Country: Sweden
First Name: Matt
Found out yet what it means?
post #5 of 5 (permalink) Old 06-06-2012, 08:03 AM
Very cool.
I took a look at the Festool MFT, but it looks like the accessories are super expensive. Those clamps are cool, for instance, but it's $110 for a pair!
gsk3 is offline
Work bench top hdusch Project Plans and How To 5 04-05-2015 03:09 PM
Table top display cse. derek willis Show N' Tell 16 04-13-2014 06:31 AM
Router table top? Rick in Pittsburgh Table-mounted Routing 11 09-26-2010 09:24 PM
How to best attach router table top to cabinet? xvimbi Table-mounted Routing 3 05-28-2010 07:30 AM
Office cubicle table top for router top Noob Table-mounted Routing 12 05-23-2009 07:35 AM
