Drill Press Dust Control - Router Forums
post #1 of 20 (permalink) Old 06-08-2012, 11:40 AM Thread Starter
Gaffboat's Avatar
First Name: Oliver
Default Drill Press Dust Control
After the mess of drilling holes for euro hinges in MDF, I decided I needed to get a handle on dust control for the drill press. I purchased a 2 1/2" Flexform Hose that can be bent and contorted to a variety of positions. That was the easy part.
The hard part was trying to puzzle out the best way to attach it to the drill press. The attached photos show my solution.
I started by gluing two splicers to a 90 degree elbow (photo DPDC_1). Then I made a bracket out of 3/4 ply and aluminum bar to hold the elbow assembly. (photos DPDC_2 and DPDC_3)
The bracket was attached to the underside of my drill press table and the elbow clamped in the bracket (DPDC_4 and DPDC_5).
Photo DPDC_6 shows the final assembly and the final two photos show the result of drilling MDF with a forstner bit without the vacuum and with the vacuum. Since the Flexform hose is attached to the table instead of the drill press column it is always in the correct postion no matter how much I raise or lower the table.
Gaffboat is online now
post #2 of 20 (permalink) Old 06-08-2012, 11:59 AM
Guest
First Name: Robert
Great set up Oliver. I for sure need one of those for when I'm sanding.
57759 is offline
post #3 of 20 (permalink) Old 06-08-2012, 01:05 PM
papawd's Avatar
First Name: warren
Nice, I have dust collection on everything but my drill press
papawd is offline
post #4 of 20 (permalink) Old 06-08-2012, 01:45 PM
kp91's Avatar
First Name: Doug
Oliver,
Very professional looking installation! Thanks for sharing.
1 John 1:9
Fredericksburg, VA
kp91 is offline
post #5 of 20 (permalink) Old 06-08-2012, 02:33 PM
OPG3's Avatar
First Name: Otis
Oliver, That is a great-looking setup and your photos are perfect! You impress me as someone who could teach Karate via the internet! I am very impressed! Your idea of keeping the pickup "parallel" to the table is very solid! Keep-up the good work and Thanks for Sharing that!
OPG3
Tweak everything!
OPG3 is offline
post #6 of 20 (permalink) Old 06-09-2012, 06:09 AM
Very nice set up. But if you want to see how well it works, drill a few larger holes with a forstner bit. Something that will produce some bigger chips.
I put DC on my drill press some time ago. But mine is attached to the back side of the fence. All I have to do is push/sweep the dust and chips to the cut out in the fence, and away it does. But sometimes the larger chips from forstner bits get caught up in the 2" hose.
jsears is offline
post #7 of 20 (permalink) Old 06-09-2012, 06:10 AM
First Name: Peter
Very good setup Oliver.
Could I trouble you for a few extra photos of the table you've made for the drill press, please....some dimensions too if possible, thank you.
Cheers, crowie
crowie is offline
post #8 of 20 (permalink) Old 06-09-2012, 07:43 AM
cagenuts's Avatar
Country: South Africa
First Name: Hilton
Send a message via Skype™ to cagenuts
So are the pipes below and above the table or do you alternate them?
cagenuts is offline
post #9 of 20 (permalink) Old 06-09-2012, 12:21 PM Thread Starter
Gaffboat's Avatar
First Name: Oliver
Cheers, crowie
It's really a very simple and basic table. Dimensions are 16" deep x 24" wide and constructed out of MDF. The attached file has more detailed photos. The original table on the drill press is 11" x 11" cast iron. The new table is attached with two screws to an 11" x 12 1/2" sub-base made from 3/4 ply that is bolted to the original table.
After owning my drill press for over 30 years I realized I didn't use it enough because trying to balance and drill on the original tiny table was too annoying. Now that I have built the table, I use my drill press constantly and confidently. It made drilling the holes for euro hinges in eight cabinet doors a piece of cake. Now I no longer have to futz with the Rockler jig I bought.
Check out the attached file and let me know if you have any other questions.
post #10 of 20 (permalink) Old 06-09-2012, 12:29 PM Thread Starter
Gaffboat's Avatar
First Name: Oliver
I just attach the hose from my shop vac to the 90 degree elbow under the table. The hose goes to a Dust Deputy saw dust collector which is, in turn, attached to my shop vac. The FlexForm hose is attached above the table and can easily be used or moved out of the way as needed.
Drill DP15501 15" Drill Press allthunbs Ridgid Manuals 2 01-18-2018 12:13 AM
Picture of my Drill Press recently finished RLego Tools and Woodworking 5 07-12-2013 03:13 PM
Drill PRess.. help me pick please!! woodaholic Tools and Woodworking 8 09-13-2011 10:53 PM
Dust control with Dovetail jig 603Country Jigs and Fixtures 6 12-06-2010 01:29 PM
All thread for router skiis rstermer Jigs and Fixtures 99 08-09-2009 10:54 AM
