box hand-hold jig - Router Forums
post #1 of 6 (permalink) Old 06-11-2012, 05:52 PM Thread Starter
First Name: Jerry
Default box hand-hold jig
I am looking for a jig that will allow me to create a hand-hold on the side of a box. I would rather not attach a carrying handle. I am looking for a way to create a hold into the side of the box.
Perk318 is offline
post #2 of 6 (permalink) Old 06-12-2012, 12:20 AM
You could use a bit like this - Lee Valley Tools - Important Announcement. You might need to rout the basic opening with a straight bit first. You don't have to buy this bit from Lee Valley. Mnay manufacturers make something like it.
post #3 of 6 (permalink) Old 06-12-2012, 06:57 AM
First Name: Art
If this is going to be a one time thing then why not drill a small home and use a coping saw to cut out the desired shape. It will take longer to make a template and set up the router than to make the actual hole.
mgmine is offline
post #4 of 6 (permalink) Old 06-12-2012, 09:44 AM
prgl7's Avatar
First Name: George
try a finger pull bit. examples:
CMT 855.602.11 FINGER PULL BIT at Amazon.com: CMT 855.602.11 FINGER PULL BIT: Home Improvement
Bosch 84540M 1-7/8-Inch Diameter 1-5/32-Inch Cut Carbide Tipped Finger Pull Router Bit 1/2-Inch Shank at Amazon.com: Bosch 84540M 1-7/8-Inch Diameter 1-5/32-Inch Cut Carbide Tipped Finger Pull Router Bit 1/2-Inch Shank: Home Improvement
Magnate 7402 Drawer/Finger Pull Router Bits - 1" Overall Diameter; 1/2" Cutting Length at Amazon.com: Magnate 7402 Drawer/Finger Pull Router Bits - 1" Overall Diameter; 1/2" Cutting Length: Home Improvement
prgl7 is offline
post #5 of 6 (permalink) Old 06-12-2012, 10:13 AM
Hi Jerry - for a one-of project, just a couple of large holes, forstner bit, hole saw or even a spade bit will get it started. Connect the holes with a jig saw and ease the edges with a small roundover.
For multiple items, make a template about the same way except account for bushing offset (if planning on using bushings, pattern bit will do also) and use a plunge router. Again, ease the edges.
They also make a bit just for that:
Amazon.com: Freud 99-019 1-Inch Convex Edge Router Bit: Home Improvement
I've never used one of those and have no idea how to guide it, possibly with bushings
John Schaben
jschaben is offline
post #6 of 6 (permalink) Old 06-12-2012, 12:20 PM Thread Starter
First Name: Jerry
Thanks for all of your suggestions, but I made a jig that held the material that I was using for the side of the box on a 20 degree angle and then use a Fostner to cut the hand hold. I used a 1" bit and plunged it along a 4" inch section of the material. As I plunged the bit down, it cut a nice smooth hold with a flat bottom. Once I cut my first hold, I moved the material 3/4" to the left and repeated the process. A little sanding and the hand-hold insert was complete.
Perk318 is offline
EZ Dovetail Jig bobj3 Jigs and Fixtures 12 01-14-2020 07:20 PM
Oak park box jig on Bosch 1171 table RegisG Table-mounted Routing 13 10-14-2011 08:47 PM
Did you make a box for dovetail jig? volunteers Jigs and Fixtures 5 08-26-2011 01:37 PM
1/4 Box joint jig 46_trap Tools and Woodworking 2 10-28-2005 06:26 AM
