adjustable angle jig? - Router Forums
post #1 of 11 (permalink) Old 06-13-2012, 07:42 PM Thread Starter
MAFoElffen's Avatar
Default adjustable angle jig?
Okay, I need ideas.
I have raised panel bits of different profiles. I am trying to match a profile of existing doors. Unfortunately I don't have anything close to it.
It is a 3/4" panel. The cut on the back is 3/16 down, straight cut for 1" with a 1/4 cove. That is easy to recreate.
The front is 5/16" down, straight for 3/8" inch, 1/4" radius cove, rising up at 15 degrees to a 3/4 radius cove, ending at 1 3/8" in. The angled cut is what is challenging me.
If I built an angled lift or if I got my radial arm saw going... but I'm not there yet. In the past I've secured angled stock onto a workpiece....
I'm thinking that since I have 5 doors to build, that I should either make an angled jig for those panels or make some kind kind on angled jig for a router.
I didn't find anything on a search here in the forum. Has anyone built anything that might work? Any ideas would be very welcome.
MAFoElffen is offline
post #2 of 11 (permalink) Old 06-13-2012, 08:13 PM
This will give you a good idea of how to cut the angles. What you can not see in this photo is that the fence is a joiner fence with an offset between the input and output sides.
Another solution is the Verticaly tilting router table by Pat Spielman.
Name:	Angle jig 3.JPG
post #3 of 11 (permalink) Old 06-14-2012, 06:14 AM
I am no expert, but Mathias Wandel at woodgears dot ca has many examples of duplicating moldings and building tilting router lifts. Also at StumpyNubs dot com he has a shop built raised panel jig that is nice.
I am not allowed to post url names because I don't have enough posts, but tried (in words) to give you some opportunities to research avialable options.
flockshot is offline
post #4 of 11 (permalink) Old 06-14-2012, 09:07 AM
CharleyL's Avatar
First Name: Charley
The folks at Woodhaven offer a fixture for tilting a router. You could add it to your router table.
Angle Ease : Router : Woodhaven
Charley
Central North Carolina
CharleyL is offline
post #5 of 11 (permalink) Old 06-14-2012, 09:38 AM
MLCS Horizontal Router Table
http://www.routerforums.com/table-mo...le-update.html
post #6 of 11 (permalink) Old 06-14-2012, 03:41 PM Thread Starter
MAFoElffen's Avatar
Thanks Mike.
I just go back from the VA, sat down and went through everyones links, pictures, videos, articles...
Looks like the Vertical Tilting Router Table is a variation of the tilting router lift that the next poster posted. Actually, I had seem that tilting router lift is one that I had looked into and debated with getting my RAS going again... That poster also posted a jig that is actually a router table with a sliding tilting table deck.... But the router itself is fixed.
Of all the routers I have, I don't have one that I feel comfortable about building a tilt mount for without a lot of extra fabrication. None of my 1/2" routers have a round housing without the base. I am saving up for one that would be perfect, but I'm on disability right now = very fixed income. It is a a goal. All that is another discussion. I don't have the time or money for that yet.
I was really interested on your photo Mike. Problem was the picture is blurry if you look at in original size. If you don't have a better picture of it, could you please describe it to me?
Mike- That picture, even though I couldn't see it in detail, reminded me of an angled miter router jig. An angled miter router jig is 2 rectangular panels (same size), joined at a long edge with 2 hinges. At the each end of the bottom panel is secured 2 small pieces of stock that stand straight up. In those pieces you cut an arched slot to secure to the upper panel using hanger bolts/washer/wingnut, like an arched quadrant stay in a drop lid desk. Could also drill holes for screws at predetermined angles. This jig, you open the upper panel to the angle you want, and secure on the ends to keep it at that angle. You usually put your work on top the upper panel (clamps) and slide the jig along the fence.
Problem with that jig is that you are routing the edge of the work. But for some reason, looking at "your" picture gave me an idea... If I build another angled miter sled and put a ledge on the lower edge, then secure it to my workbench. The workpiece is at the angled... Then build a skeleton that can support rails, but be adjustable verticaly and keep in square/perpendicular to the benchtop... Then I could make a bigger (40") mortise slot jig (with stops) to use a router.
post #7 of 11 (permalink) Old 06-14-2012, 04:33 PM Thread Starter
MAFoElffen's Avatar
Thanks Bob! Nice. Is that yours?
Post 1 (yours), photo 2... If you rotated the whole thing 90 degrees. Could then use a free router supported by a jig above it, instead of one mounted in table... That would be what I am picturing in my head. About to go out to the garage to get it out of my head into making shavings.
I guess I could always redo one of my router tables if I carve out some mounts, but I surely don't have $250 right not to buy someone else's pre-made mount or jig... That's almost as much as the new router I've been saving for.
post #8 of 11 (permalink) Old 06-14-2012, 08:44 PM Thread Starter
MAFoElffen's Avatar
Last night as I was thinking about this, I thought if I built I took my angle miter router sled and put something underneath (to lift it up higher), that mybe I would have enough material hangover to route where I need to cut.
As I started building my new angle miter router sled/jig, I looked at my 1/4", 3/8" and 1/2" plywood... I had started tearing down my horse shoeing trailer and I have all this 3/4" marine plywood from it. That's what I used instead of the thinner material.
It worked out just fine. At 1 1/2 inches (2 x 3/4") at 15 degrees, it gave me 6 1/2" of workpiece hangover. I made test cuts on my router table and recreated the profile.
I didn't have to build anything to suspend a router above the angled work.
Thanks All!
post #9 of 11 (permalink) Old 06-14-2012, 08:55 PM
Hi Mike
" (yours) " = yes, I have two of them and they work great for the hard router jobs but for the real hard jobs I use a RAS with a router fix to it....LOL it will do any angle I need..the stock is flat but the head can be set at what I need.
see my uploads of many shots of it.
post #10 of 11 (permalink) Old 06-15-2012, 12:17 AM Thread Starter
MAFoElffen's Avatar
Hi Mike
LOL... Over 1,100 pages of uploads. Say loads of shots of it. 4 router tables? The sewing machine, the table with the 1/2" see thru plate and 2 mlcs... I really like that mlcs. Have ideas running rampant through my head about that table. Sweet.
Looked at pic's of your RAS. Remember, I'm the one with the Montgomery Wards Power-Kraft RAS that is going to have a router chuck adapter machined for mine. I really like your table. I saw graduations and 2 metal bars that looked like they pivot in the center and lock on the outside? Is that right? That for setting up "workpieces" for a miter instead of your head adjust and your work against the fence?
Router Adjustable Dado Jig Barry_White Jigs and Fixtures 18 07-20-2010 03:36 PM
Angle Jig bobj3 Jigs and Fixtures 2 08-07-2007 06:44 PM
