Dovetail Routing - Router Forums
post #1 of 3 (permalink) Old 06-14-2012, 11:22 PM Thread Starter
First Name: david
Default Dovetail Routing
I have a Keller 1500 and was just wondering since the bits that goes to that jig has a 5/8" bearing on them can i use a 5/8" guide bushing and the size bit that is shown which is a 7 degree router bit w/ a 3/4" cutting depth for the dovetail and a 916" for the straight bit. I think i will have a problem when using the straight bit because of the ID on the bushing.
Please Reply Here:
[email protected]
Sincerely Dave
david cooksey is offline
post #2 of 3 (permalink) Old 06-15-2012, 11:54 AM
You can use a guide bushing if you want as long as the cutter is the same size. The bearing does ensure that the cutter is centered. If using a bushing just make sure it is centered with the center of the collet when you tighten it down to the base so your bit is centered in the bushing.
Whittier, CA.
Have a nice & safe day!
jlord is offline
post #3 of 3 (permalink) Old 06-16-2012, 08:01 AM
pretender's Avatar
First Name: Gary
I have the same jig and you can order the correct bit from Peachtree. It is the one required foe making box joints on the jig.Gary
pretender is offline
Dovetail routing jimahern General Routing 4 01-12-2011 08:26 PM
How do I defeat tear-out while dovetail routing? mjdtexan Jigs and Fixtures 14 11-04-2010 05:24 PM
using a dw625 for dovetail routing overthehill General Routing 5 02-16-2009 08:53 AM
Dovetail Routing jimcrockett General Routing 2 11-25-2008 08:09 PM
Dovetail routing R-Man General Routing 4 10-11-2007 09:14 AM
