Need flip stop suggestions - Router Forums
post #1 of 25 (permalink) Old 06-19-2012, 05:45 PM Thread Starter
Gaffboat's Avatar
First Name: Oliver
Default Need flip stop suggestions
As I mentioned in my Acme Dowel Cannon post, I found stuff during my bi-decade bench cleaning. Among them was a nice spring-loaded cabinet hinge.
I thought it might be perfect for making a flip up stop for my miter saw fence. The original which is just an L shape (Photo 1) works very well but I often wish I could just flip it out of the way.
The hinge seemed like a good idea and it seemed to be pretty tight. So I made a new stop using the hinge (Photos 2, 3, and 4).
The good news:
1. It is easy to position.
2. It looks nice.
3. It flips up and down well.
4. Did I mention it looks nice?
The bad new:
1. It sucks.
2. It sucks.
3. It sucks.
4. Beauty isn't everything.
The problem is the hinge has more lateral play than I thought so there is about 1/16" to 3/32" of play in the stop. Okay, I know Kreg and others make nice, strong flip stops but Rockler already owns my soul and Grizzly, Woodcraft and the others are fighting for whatever is left. I don't really want to spend money on a 'convenience'. When it comes right down to it, my original works fine.
So, help me out here. I know you guys have suggestions.
Gaffboat is online now
post #2 of 25 (permalink) Old 06-19-2012, 07:57 PM
Guest
First Name: Robert
The good news:
2. It looks nice.
The bad new:
1. It sucks.
2. It sucks.
3. It sucks.
To use that hinge it looks to me as if the pin will need to be removed and the barrel halves shimmed with a washer the correct thickness so there is zero lateral movement.
57759 is offline
post #3 of 25 (permalink) Old 06-19-2012, 08:23 PM
OPG3's Avatar
First Name: Otis
Oliver,
I understand your question, but am left wondering...can you not just slide the flip-stop beyond the limits of your (at hand) workpiece?
OPG3
Tweak everything!
OPG3 is offline
post #4 of 25 (permalink) Old 06-19-2012, 09:39 PM Thread Starter
Gaffboat's Avatar
First Name: Oliver
Originally Posted by OPG3 View Post
Oliver,
Yes I can, but that sometimes entails actually sliding it off the end of the T-track. Then it takes a bit longer to get it back in place. It would be convenient if I don't lose the original placement so that all cuts are exactly the same.
post #5 of 25 (permalink) Old 06-20-2012, 01:07 AM
Oziray's Avatar
First Name: Ray
Exchange the recessed hinge for a brass hinge, no play or slap in the knuckle if you get a reasonable quality one
Oziray is offline
post #6 of 25 (permalink) Old 06-20-2012, 08:23 AM
Default Too much play
If the play is in the hinge, replace the hinge with a nice heavy duty 3.5 or 4" door hinge.
If it's loose at the lockdown, the longer hinge will provide more surface area and room for another lockdown nut.
Enjoy,
Kevin
kmacrae354 is offline
post #7 of 25 (permalink) Old 06-20-2012, 01:48 PM
Noob's Avatar
First Name: Paulo
If your willing to abandon using that hinge and go a different route, take a look at the attached PDF. Since you already have a t-track isntalled, it would work perfect for you, just modify the dimensions accordingly.
Noob is offline
post #8 of 25 (permalink) Old 06-20-2012, 02:31 PM
Honored Member
First Name: pat
Stop on drill press fence, albeit not to your distance requirements, will not slip.
There is no backlash in it.
Quillman is offline
post #9 of 25 (permalink) Old 06-20-2012, 03:16 PM
Hi
Just one more way,,,a simple tee slot in some MDF with some slide blocks for stopping points on both sides of the chop saw blade, I also use the same thing on my RAS..
No slop dead on every time
post #10 of 25 (permalink) Old 06-20-2012, 03:45 PM
Holy Hanna! It's either that or a new BMW...:0
DaninVan is offline
Suggestions on finishing dollhouse bradinc DIY and Renovation 4 06-24-2014 08:16 PM
Router and software suggestions PrinterLCNM CNC Routing 9 06-02-2011 08:12 AM
CC Sled Stop Block Slide Ghidrah Show N' Tell 2 04-21-2009 03:27 PM
home made ruler stop allthunbs Jigs and Fixtures 19 01-03-2009 03:44 PM
