My router circle jig - Router Forums
post #1 of 10 (permalink) Old 06-30-2012, 11:32 PM Thread Starter
harrysin's Avatar
First Name: Harry
Default My router circle jig
A member sent me a PM asking if I could post a link to the making of my circle jig. Unfortunately I made it years before I had a digital camera, however I have over the years posted several photographs which I'll attempt to round up and post here. It must be remembered that the measurements shown are for the MAKITA 3612/C and 3600BR and must be adjusted to suit the router to be used with the jig. It is possible to utilise the MAKITA side fence which avoids having to source the mild steel rods. Possibly other brands can also be used.
Harry
harrysin is offline
post #2 of 10 (permalink) Old 07-01-2012, 05:55 AM
First Name: Peter
Thanks Harry, much appreciated.....Cheers, crowie
crowie is offline
post #3 of 10 (permalink) Old 07-01-2012, 09:06 AM
grbrico's Avatar
First Name: Greg
Thanks Harry. Great photos!!!
Greg
grbrico is offline
post #4 of 10 (permalink) Old 07-01-2012, 11:52 AM
Gap_308's Avatar
First Name: Scott
Thanks Harry. The pictures explain so much. Now where did I leave that metric conversion chart....
Thank You Veterans
Gap_308 is offline
post #5 of 10 (permalink) Old 07-04-2012, 04:59 PM
Mike Wingate's Avatar
First Name: mike
It's a great jig to have and use. Mine is made from a kitchen cutting board.
http://i130.photobucket.com/albums/p...g/PICT0337.jpg
Mike Wingate is offline
post #6 of 10 (permalink) Old 07-05-2012, 11:45 AM
Knothead47's Avatar
Thanks for sharing the photos and specifications!
Fair dinkum, I believe is the right term.
John T.
Knothead47 is offline
post #7 of 10 (permalink) Old 07-09-2012, 04:08 AM
First Name: Peter
G'Day John,
Well done from "On Top Down Under",
you'll soon be an Aussie.....
Cheers, crowie
crowie is offline
post #8 of 10 (permalink) Old 07-09-2012, 01:10 PM
First Name: Chris
Harry, would you mind giving a short description of how it works and its setup and usage?
Chris Curl is offline
post #9 of 10 (permalink) Old 07-22-2012, 04:57 PM
First Name: Mark
I was planning on making a small circle jig but the plan I was basing it on would have meant 5 times as much work as this and double the set up fiddling with a miniscule increase in versatility.
Am heading out to the shop to find the router side fence, I know I've seen it somewhere :-|
Thanks Harry
Mark
Mdawson is offline
post #10 of 10 (permalink) Old 07-23-2012, 07:18 AM Thread Starter
harrysin's Avatar
First Name: Harry
There are four Tee nuts set into the jig,a pin screws into the one that will achieve the desired radius, this is the course adjustment. The router slides onto the rails and locked when the EXACT radius is achieved. In use a circle of the desired size in drawn using a compass and a hole, the same diameter as the fulcrum pin is drilled through the centre of the circle and preferably through into a sacrificial bench top. This ensures that when the bit penetrates the material, the centre piece will be held in position with no chance of it touching the still revolving bit.
Several length pins allow for different thickness material, these can be made from carriage bolts which have a long section without thread. The only tools required being a hacksaw and file.
Harry
harrysin is offline
Getting Started With A Woodworking Router. learnexperience Table-mounted Routing 9 10-22-2014 06:43 PM
I think my old router nearly killed me! peacefrog General Routing 23 01-26-2014 11:36 AM
Hello DPugmire New Member Introductions 5 11-08-2010 06:29 AM
