cutting small oval - Router Forums
post #1 of 8 (permalink) Old 07-15-2012, 11:08 AM Thread Starter
First Name: Derek
Default cutting small oval
Hello All, I need to cut a small oval 4"by6". I do have the jig by Rockler but the smallest it will do is 9"by17". How do i get it down to the smaller size?
Thanks,Derek
dirkhallsz is offline
post #2 of 8 (permalink) Old 07-15-2012, 05:16 PM
Thanks,Derek
Hi Derek - That's a pretty small oval to try to get out of a jig. You could make a larger one and start reducing it down with guide bushings until you get right size template. With a 9"x17" to start with that's a lot of reducing though. Eagle america does sell a package of Oval templates but the closest they have is a 5x7.
Picture Framing - 6 Piece Clear Oval Picture Frame/ Plaque Set
The 5x7 wouldn't be to tough to reduce though.
Another option would be to check Walmart or second hand stores like Goodwill for an oval picture frame you could use for a template.
Good Luck
John Schaben
jschaben is offline
post #3 of 8 (permalink) Old 07-15-2012, 06:07 PM
Welcome to the forum, Derek.
Could you please modify your profile to let us know what equipment you have to make this ellippse?
I would use your Rockler jig to make a male template 9 x 17 and then use template guides with plastics spacers to make smaller templates.
Bobj3 may be along to help you here as he has posted on this topic many time and has also modified his Rockler jig to make very small ellipses.
Sydney, Australia
jw2170 is offline
post #4 of 8 (permalink) Old 07-16-2012, 09:13 AM
First Name: Dick
Depending on how many you have to make, I would rough cut the oval on my band saw and then using a pattern bit and a pattern (already cut to size). Trim to size on a router table. You will need to watch and control the direction of the trim to avoid chipout.
dick in ia is offline
post #5 of 8 (permalink) Old 07-16-2012, 01:35 PM
Hi Derek
The Rockler Oval jig will do it all for you, you can rework the Rockler jig so will cut 3" x 5" Ovals,,you need to make a new base plate,out of some MDF and rework the main part of the slot in the jig so it can move all the way to the center hole ...very easy rework job and worth the time to do it..plus you don't need to bolt your router to the main part..
You can see it my Uploads for many pictures and how to do it//>>
post #6 of 8 (permalink) Old 07-16-2012, 07:43 PM Thread Starter
First Name: Derek
Hello Bob,
What is the ring in the 2nd picture for? Maybe i am missing something. Also where do you get the brass bushing.
post #7 of 8 (permalink) Old 07-16-2012, 08:41 PM
Hi Derek
Picture 2 is just to show you it can also be use the jig for a great cir.jig (from 3" up )
The bigger guides you can get from Lee Valley the smaller ones also but you can get them at a better price from HF
1-3/4" Brass Template Guides - Lee Valley Tools
1-3/16" Brass Template Guides - Lee Valley Tools
9 Piece Router Template Guide Set
The 5/32" drill is used for the rework for the cir jig.makes it quick and easy to make a cir.cut outs..
Hello Bob,
post #8 of 8 (permalink) Old 07-17-2012, 11:26 AM
neiltsubota's Avatar
First Name: Neil
Default I Don't Get it....either......Did it end up 4X6 ?
Hello Bob and Dirk,
I don't get it either.
I can see Dirk's need. Most Photos use to come out of the lab in 4" x 6" when everyone was shooting film. Today digital photos are depended upon who "processes" the image and the Camera's Sensor size, lens, and a whole bunch of other stuff.
Take a photo of a tape measure, or reference with a $ 100.00 bill....(grin)...
Neil
Hi Derek
neiltsubota is offline
Cutting with the router davidmur2 General Routing 4 04-23-2012 10:54 AM
Profile Cutting Options BobCAD CAM aldepoalo CNC Routing 0 02-08-2012 10:49 AM
oval & circle cutting jigs frosty50 Jigs and Fixtures 3 12-22-2011 01:41 PM
Cutting out Circles and Arcs the Easy Way learnexperience Portable Routing 1 11-26-2011 01:29 PM
Cutting circles on the table crquack General Routing 10 11-04-2008 09:05 PM
