Circle Cutter - Router Forums
 2Likes
post #1 of 11 (permalink) Old 07-23-2012, 04:13 PM Thread Starter
FourEyes45's Avatar
First Name: Walt
Default Circle Cutter
Im new using the Router but this ol man is trying.. I want to cut some holes in plywood for Corn Hole boards..so the kids at Church can enjoy...I looked at hole saws and they were anywhere from $30-$80. After looking at some on the net I said to heck with it...If it works so be it if not nothing lost but a little time and a cutting board... Will try and load a couple of pics.
FourEyes45 is offline
post #2 of 11 (permalink) Old 07-23-2012, 05:24 PM
Gaffboat's Avatar
First Name: Oliver
Looks like a nifty job and will work well. You'll be glad you saved the money on the hole saws. Now you've got to think of something to explain what happened to the cutting board.
Gaffboat is offline
post #3 of 11 (permalink) Old 07-23-2012, 06:08 PM
Neat idea, using a cutting board, Walt.
Did you use a jig of some sort to drill all the holes, and what is their spacing?
Sydney, Australia
jw2170 is offline
post #4 of 11 (permalink) Old 07-23-2012, 08:14 PM Thread Starter
FourEyes45's Avatar
First Name: Walt
I got the cutting board at Sams and I used a rule to mark the holes..(the rule had 1/8 markings) I drilled every 2/8" the smallest hole I can cut is 6" Thanks for looking.
post #5 of 11 (permalink) Old 07-24-2012, 08:42 AM
RouterForums.com User
harrysin's Avatar
First Name: Harry
Beautifully made Walt but it would not only have been easier to make this from thin plywood, but a panel pin could be tapped through it to make exact size holes. One improvement I would suggest to the one you have made is to increase the size of the centre hole to that of the router, this will allow you to SEE the bit in action.
rcp612 and grbrico like this.
Harry
harrysin is offline
post #6 of 11 (permalink) Old 03-06-2015, 02:38 AM
First Name: Paul
Thanks for photos & PDF
Paul Brierly is offline
post #7 of 11 (permalink) Old 03-06-2015, 02:48 AM
get the boards at dollar store...
way cheaper...
Stick486 is offline
post #8 of 11 (permalink) Old 03-06-2015, 11:04 AM
Ghidrah's Avatar
First Name: Ronald
Agree you need a bigger bit hole, seeing the bits position in relation to the circle, inscribed/circumscribed will make your life easier.
Ghidrah is offline
post #9 of 11 (permalink) Old 03-09-2015, 07:42 AM Thread Starter
FourEyes45's Avatar
First Name: Walt
Thanks for looking and the hints..It will come in handy...Always like to see what others say..
Walt
post #10 of 11 (permalink) Old 04-22-2015, 01:42 PM
First Name: David
Not only that but it will allow for better chip ejection... which will keep the bit cooler and prolong bit life. This is assuming that he is using a spiral or sheer angle up cut vs down cut.
thedavel is offline
Cutting out Circles and Arcs the Easy Way learnexperience Portable Routing 1 11-26-2011 01:29 PM
Circle cutter use Kelly Rittgers Jigs and Fixtures 10 02-01-2011 09:52 AM
circle cutter Old_Chipper Show N' Tell 27 01-25-2010 11:23 AM
Circle Cutter (Trammel) RustyW Jigs and Fixtures 6 05-13-2008 11:44 PM
Cutter for circle jig jer760 Jigs and Fixtures 4 02-06-2008 06:16 PM
