Trying out a new fence system - Router Forums
post #1 of 7 (permalink) Old 08-11-2012, 11:19 PM Thread Starter
First Name: Chris
Default Trying out a new fence system
I am working on a new fence system. It is made with those large free paint stirrers from Home Depot.
There is a slot in the middle for bolts, and the bottom is indented so it can hold carriage bolts from underneath.
It also has t-nuts in the back so they can be built into a larger system, like the 2 sides of a router table fence for example.
Chris Curl is offline
post #2 of 7 (permalink) Old 08-12-2012, 01:34 AM Thread Starter
First Name: Chris
I just figured that I can stack them vertically too to make taller fences. And if I use spacers, I can make tracks on the front for things like feather boards and bit guards and stuff.
Version 2 is going to use a yardstick on the front so i can set the stop blocks with precision and repeatability.
I think this system is going to work out amazingly for me.
post #3 of 7 (permalink) Old 08-12-2012, 02:48 AM
MAFoElffen's Avatar
Looks good and functional.
Aren't paint stir sticks about a 1/4 thick? (They are.) I have a TS sled with those as spacers between 2 pieces stacked as it's fence. I use a carraige bolt in the resulting slot, wing nut and block for an adjustable stop block.
MAFoElffen is offline
post #4 of 7 (permalink) Old 08-12-2012, 03:04 AM Thread Starter
First Name: Chris
yes, they are pretty much exactly 1/4" thick, and essentially (maybe a tad under) 1 1/2" wide.
and yep, stop blocks and pretty much anything else you want to attach to either the top or front will be a piece of cake.
post #5 of 7 (permalink) Old 08-12-2012, 08:00 AM
First Name: Keith
Nice job
Woodshaper67 is offline
post #6 of 7 (permalink) Old 08-12-2012, 10:05 AM
OPG3's Avatar
First Name: Otis
Chris, this has similarities (on a much smaller scale) to a Glu-Lam beam (a.k.a. Boozer Beam) when there are no spaces. Glu-Lam's are amazingly strong for structural framing. These often are visible inside an unfinished garage as a lintel member. Glu-Lam's are like gymnasts - strong and heavy only where they need to be - so much of the strength comes from the glue-lines. Also, I like your sacrificial board under the "hole to be drilled" - as it appears that board is easily removable without a lot of work. So often, people forget the sacrificial boards and the fact that they have a very short lifetime! Great work!
OPG3
Tweak everything!
OPG3 is offline
post #7 of 7 (permalink) Old 08-13-2012, 12:19 PM
CharleyL's Avatar
First Name: Charley
It looks like Home Depot is going to have a run on paint sticks. I wonder if they keep track of the number of paint sticks given out to the number of gallons of paint sold....Interesting! I never measured them. Maybe I'll have to create something with paint sticks too.
Charley
Central North Carolina
CharleyL is offline
Mule Accusquare rip fence M1050 westend Tool Reviews 9 03-02-2015 12:19 PM
Vacuum System Almost Finished MEBCWD Show N' Tell 5 02-09-2012 10:17 AM
Spacer Fence System 29394 Table-mounted Routing 2 05-30-2010 01:15 AM
Outlook Express problems BrianS Lobby 6 01-06-2008 08:23 AM
