Raised Panels: Router vs. Table Saw??? - Router Forums
post #1 of 78 (permalink) Old 08-19-2012, 11:50 PM Thread Starter
First Name: Keith
Default Raised Panels: Router vs. Table Saw???
Raised panels add a great finishing touch to many wood working projects such as cabinets doors, architectural elements, furniture and passage way doors. Creating the raised panels may be more straight forward than you would think. The knee jerk reaction is to think this can be accomplished with a router, router table and ogee bit, of course. Easier said than done; anyone who has attempted this with a router knows extreme care is paramount. Big diameter bits (>3"-diameter) spinning at 10,000-rpm can be intimidating. Add to the equation creating a raised arched panel and that means attempting the feat without a router fence...Yikes!
Enter the table saw. Yep, I said table saw. Now raised panels can be fabricated via a tricky little jig attached to the keystone of every wood shop. Advantages? The raised panel is easier to handle on the table saw, especially when long raised panel cuts are needed and you get a true straight cut. The raised panel jig has a high fence (24"-Tall) and a perpendicular foot that the saw blade protrudes through at 12.5-degrees. This set up gives excellent stability and allows hand positioning well away from the saw blade enhancing control and improving safety. I did an experiment with multiple increasingly deep cuts and with one pass full depth cut. The one pass full depth cut is definitely the way to go...it is slower but the end product is much cleaner and requires way less finish sanding.
Give the table saw due consideration when fabricating your raised panels.
Name:	2012-08-18 14.19.58.jpg
Name:	2012-08-18 14.29.46.jpg
Name:	2012-08-18 14.23.55.jpg
Name:	2012-08-18 14.20.47.jpg
PorterCable690 is offline
post #2 of 78 (permalink) Old 08-20-2012, 06:35 AM
CharleyL's Avatar
First Name: Charley
I've made raised panels both ways and prefer using a 3 hp router in the table but it takes a solid table and a good setup to get good cuts. Down force feather boards are needed to keep the work against the table and they can't be located above the area that will be cut. The only time that I don't use my router table fence in addition to the bearing on the bit is when cutting the arched edge of the panels. If the panels are arched I will cut all sides of the panel on the router table with the same setup, only removing the fence when doing the arched side. A round bit guard above the bit is then used.
A table saw will do a good job of raising panels, but it can only do the straight non-arched cuts. Arched panels that were built before shapers and routers had their arched edge hand carved. This is still done if the arch requires a tight inside curve that can't be completely cut because of the large diameter of the router bit or shaper cutter.
Charley
Central North Carolina
CharleyL is offline
post #3 of 78 (permalink) Old 08-20-2012, 06:52 AM
First Name: Sue
Default Depends on the quality of the table-saw....
Hi, I have this dilemma as I'm making lots of frame and panel - fitting out my house. My tablesaw is a wonderful old Wadkin PK, but the blade seriously needs replacing which I can't afford at the moment, and the wobble makes for too much work cleaning up. My trusty old Hitachi 2hp router, with a home-made router table does the job with minimal cleanup afterwards. The trick is to do the end-grain first, so that any breakout is taken away leaving a very clean finish.
Sue-kelly is offline
post #4 of 78 (permalink) Old 08-20-2012, 09:26 AM
First Name: Duane
As most if not all the raised panels I do are cathedral arched panels with ogee or roman ogee profiles, this is not really on option for me.
However with proper tooling and jigs, they are quite easy to do and reasonably safe.
Guess it goes to show there are several ways to accomplish most things! Use the one that suit you best.
Dmeadows is offline
post #5 of 78 (permalink) Old 08-20-2012, 11:29 PM Thread Starter
First Name: Keith
The table saw is quite an amazing tool and made even more amazing with engaged imagination.
So here ya go: Make your raised panels as previously described above using the table saw for the straight cuts, then... go at it again on the table saw this time at an angle with a coping jig. Viola'.... curved raised panels! Crazy stuff...
post #6 of 78 (permalink) Old 08-20-2012, 11:49 PM
Hi
You must be joking, it can done with just one router bit and it's safe.
And all done with a $30.oo router bit and normal router table.
MLCS Raised Panel Carbide Tipped Router Bits 2
post #7 of 78 (permalink) Old 08-21-2012, 12:14 AM Thread Starter
First Name: Keith
No joke there Jigs...
Just another technique to accomplish the same goal....
Forum Definition
Public medium (such as a newspapercolumn) or place used for debates in which anyone can participate. In Roman times it meant a public place at the center of a market or town where open discussions on judicial, political, and other issues were held.
Read more: What is forum? definition and meaning
post #8 of 78 (permalink) Old 08-21-2012, 12:31 AM
OK, looks like a great way to remove fingers or to scare the bejesus out of you .
Forum Definition
post #9 of 78 (permalink) Old 08-21-2012, 04:35 AM
MAFoElffen's Avatar
It's not that bad Bob. It's a technique. I've done on table saws, radial arm saws, router tables.
Doing on a table saw... It's quick. It's easy. It's plain. You get a straight type cut. To me, that's just a step above a shaker door. I've done symmetric and asymmetric eliptical coves, but that alone is still plain.
When I'm doing restoration, if a bit or shaper cutter blade isn't available in that profile, then I'll do it on a table saw or RAS... but it takes me 3 to 4 setups/cuts on each edge to replicate the profile. Each one of those setups, if you're doing a cove cut, you have to go at about 1/4" each pass, with 1/32" on the last pass. Some of that profile might be with a bevel using a dado.
Same on my RAS. If the piece is smaller than 22", I'd rather do it on the RAS than a TS. Time and effort between tooilng steps is shorter and I can see right were each tooling setup needs to begin to blend together where the last setup ended. I have the choice of doing with a blade, dado or use router bits at beveled angles. Using router bits on an RAS still takes me 3-4 setups to replicate a profile with depth adjustments 1/4 at a time.
There's more sanding to do to get the saw marks out. I don't care what kind of blade you use, pushing sideways on a TS blade leaves tooling marks. Because of this, I found that if I use a sharp courser blade, 24 to 40 tooth, then things go faster, I don't burn the blade or work, and the results are the same quality wise. There still is more to sand to get to where a router bit or shaper blade would leave it. When doing restorations, I have to sand to clean up the tooling setup step transitions to make those separate steps into a one seamless profile.
So the comment on a table saw being easier and safer than a router table for making raised panels? Experience tells me that a router table or shaper is easier and more profiles are available. You can get more detailed and elaborate doing raised panels on a router table. You don't need to balance a panel on edge with a jig straddling the fence... Etc.
Don't get me wrong, I'm always entertained by a challenge and I love working on one of my table saws with assorted jigs, but doing raised panels on a TS for me is an alternate backup kind of thing. Sort of to the tune of: "If I have to, I can... " (But maybe not my first choice.)
MAFoElffen is offline
post #10 of 78 (permalink) Old 08-21-2012, 10:26 AM
Hi Mike
I have been using the table saw and the RAS for MANY years (50 plus years) to make door panels but the safe way with a jig but not in the cove way, just looks unsafe to me ,no need to make a easy job into a hard one and a unsafe one for me..I have all my fingers and I'm going to keep them in place..most of the stories you hear about are about the table saw or to say someone using it the wrong way..
Doing on a table saw... It's quick. It's easy. It's plain. You get a straight type cut. To me, that's just a step above a shaker door. I've done symmetric and asymmetric coves, but that alone is still plain.
Same on my RAS, but now I can also use router bits at bevel angles. Using router bits on it, it still takes me 3-4 setups to replicate a profile with depth adjustments 1/4 at a time.
And there's more sanding to do to get the saw marks out. I don't care what kind of blade you use, pushing sideways on a TS blade leaves more to sand away to get to where a router bit or shaper blade would be. When doing restorations, I have to sand to clean up the transitions between those setups to make it into a seemless profile.
So the comment on easier and safer? Experience tells me that a router table or shaper is easier and more profiles are available. You can get more detailed and elaborate doing raised panels on a router table.
Don't get me wrong, I love working on one of my my table saws with assorted jigs, but doing raised panels on a TS for me is an alternate backup kind of thing. Sort of to the tune: "If I have to..."
Getting Started With A Woodworking Router. learnexperience Table-mounted Routing 9 10-22-2014 06:43 PM
Newbie in using a Router..... Andron General Routing 6 03-20-2013 02:20 PM
Router for raised panels Jtomwoods Table-mounted Routing 5 11-03-2009 07:20 PM
Question about raised panel router bits LBrandt Table-mounted Routing 2 07-08-2006 09:47 AM
