Collar-Less Routing for Contours - Router Forums
post #1 of 4 (permalink) Old 08-20-2012, 12:51 AM Thread Starter
First Name: Keith
Default Collar-Less Routing for Contours
My mission was to advance a V-Groove accent parallel to an arc contour on a header piece. One approach would be a fab up a companion jig with the same contour, attach it to the header piece and use a collar to follow the contour throughout the arc.
Another approach would be to fab up a simple jig that attaches to the base of the router possessing two skate board bearings attached with a two 5/16" T-Bolts. The two skate board bearings ride along the vertical surface of the header allowing the advancement of a V-Groove 1-1/4" perfectly parallel to the header contour. This jig works for any path shape you want the skate board bearings to follow; beit straight, curved, arched, splined, circular, etc. Care must be taken to keep the bearings firmly against riding surface and, viola', your router bit will dutifully follow.
Name:	2012-08-18 18.41.08.jpg
Name:	2012-08-18 18.38.17.jpg
Name:	2012-08-18 18.39.48.jpg
Name:	2012-08-18 18.40.25.jpg
PorterCable690 is offline
post #2 of 4 (permalink) Old 08-20-2012, 03:16 AM
Great tip, Kieth.
Sydney, Australia
jw2170 is offline
post #3 of 4 (permalink) Old 08-20-2012, 05:49 AM
First Name: Paul
So easy! Thanks.
PRDarnell is offline
post #4 of 4 (permalink) Old 08-20-2012, 06:03 AM
CharleyL's Avatar
First Name: Charley
A great suggestion, but I would like to add a bit to it.
If you do this and want the V groove to go all the way to the end of your work, clamp a piece of scrap with the same edge profile on both ends of your work. This will give the bearings something to ride against for the short distance needed to cut the beginning and end of the V groove correctly. If you don't do this the V groove may be cut wrong as the bearings enter and leave the ends of the work because only one bearing will be in contact with the work.
There are bearing accessories available for many routers on the market that allow you to do this, but they only have one bearing, requiring you to maintain very accurate orientation of the router to the edge of the work as you make the cut. It gives you the ability to get the correct spacing, but fails in maintaining correct router orientation to the work edge.
The 2 bearing method that Keith posted is far superior for doing this. You just need to have a way to guide the bearings at the beginning and end of the cut.
Charley
Central North Carolina
CharleyL is offline
Forum Suggestion Thread Mark Site Help and Suggestions 131 02-08-2015 09:33 AM
A routing tutorial for beginners Part Four harrysin Guide Bushings and Templates 23 04-21-2013 09:31 AM
CNC routing as first routing experience ianthehenry CNC Routing 23 04-25-2012 04:24 AM
JIGS CAN MAKE ROUTING SAFER!! (lesson learned for a newbie) metzgeri Jigs and Fixtures 44 01-25-2011 11:00 AM
What tips can you share about making templates for collar guided routing? paulcomi Jigs and Fixtures 6 01-27-2006 02:33 AM
