My new router base and centering cone - Router Forums
post #1 of 8 (permalink) Old 08-24-2012, 06:09 AM Thread Starter
Default My new router base and centering cone
Just a short thread to show my new router base and new centering cone. The base was ''half'' made from 8mm lexan in our toolshop. I only had to chamfer the edges and drill the holes. The cone was also made in our toolshop from high quality steel.
The original Bosch centering plastic cone didn't look to me very well made so I decided to made my own. The other thing is that I couldn't find it in our local shops. Not that it matters but I can bet that the original Bosch cone doesn't have less that 0.01mm radial runout like mine does.
Regards;
giltic is offline
post #2 of 8 (permalink) Old 08-24-2012, 09:21 AM
Since you have the shop why don't you test a Bosch cone and see how much run out it has?
post #3 of 8 (permalink) Old 08-24-2012, 10:00 AM Thread Starter
Hi Mike;
Well, no matter how hard I've tried I couldn't find one in our local shops. If I look at the cone and the price in the picture I would say the cone is plastic and the sufrace of the cone is not machined. So after the moulding of the cone there is no other operation (like turning of the cone surface). I would say that you can't achieve radial runout of 0.01mm only by moulding.
Regards
giltic is offline
post #4 of 8 (permalink) Old 08-24-2012, 10:42 AM
First Name: Chris
cool. where did you get that nice thick piece of lexan?
Chris Curl is offline
post #5 of 8 (permalink) Old 08-25-2012, 02:18 AM Thread Starter
Hi Chris,
The lexan sheet I've got was scrap piece from some project in our toolshop. I was looking for 5mm thick sheets but all I could get at that time was 8mm.
giltic is offline
post #6 of 8 (permalink) Old 08-25-2012, 06:31 AM
Chris, do a search for local plastic companies and I am sure you will find one that can assist you in selecting the right materials for building jigs and fixtures.
post #7 of 8 (permalink) Old 08-25-2012, 06:44 AM
Hi Chris - You can also check sign making companies, aquarium mfg companies, pop machine companies. I'm out here on the outskirts of the sticks so I have to go to eBay usually. Pretty decent prices until I get to the shipping part. Here's where I got my last batch:
5 PCS OF 3/8" TK CLEAR ACRYLIC 6" DIA SHEET | eBay
Came in right at $4 per time I got shipping out of the way. This guy is out of Buffalo NY so if you live closer would likely be cheaper.
John Schaben
jschaben is offline
post #8 of 8 (permalink) Old 08-25-2012, 08:33 AM
First Name: Andy
I regularly visit a local sign shop where I have got lexan and plexi and plastic coated with aluminun peices from 1/8 to 1/2" in sizes from 2" x5" to 8' long up to 4 x8' long sometimes a few scratches or cracks, painted but mostly just vinyl that will peel off I have used a lot of it for jigs would sell for very little plus shipping Andy
andy's Den is offline
Centering cone? fooser Table-mounted Routing 7 09-08-2011 02:46 PM
Centering router base. Help! LarryN Jigs and Fixtures 4 05-24-2005 09:13 PM
Centering Base Plate -Sam- General Routing 15 01-04-2005 10:15 AM
