Best Glue For T Nuts Into MDF - Router Forums
post #1 of 23 (permalink) Old 08-31-2012, 07:48 AM Thread Starter
Gaia's Avatar
First Name: Peter
Default Best Glue For T Nuts Into MDF
Hi all,
I've been getting various bits and bobs to make up a couple of jigs. The tablesaw tenoning jig and the drill press table and fence from the Woodsmith book, shop built jigs and fixtures.
I saw Evo-Stik Multi-Purpose Impact Adhesive as being good for gluing metal to mdf.
Says forms an instant bond, not sure if should use to glue in pronged T nuts in drilled hole in mdf. As might not have time to bang in the nut before glue sets. What would be the best glue to use and availble in the UK? I can't find a threaded insert tool anywhere in the UK, anyone ideas where can get?
Cheers guys,
Pete.
Gaia is offline
post #2 of 23 (permalink) Old 08-31-2012, 08:04 AM
argoknot's Avatar
First Name: john
Peter, I use epoxy. It does a good job on holding T-nuts..
Today is the first day of the rest of your life. Live it to it's fullest.
Making sawdust by the sea in Massachusetts
argoknot is offline
post #3 of 23 (permalink) Old 08-31-2012, 08:35 AM
GulfcoastGuy's Avatar
First Name: Patrick
I'd go with epoxy, too. I like press-in's myself. I've had good experiences with some I got from McMaster-Carr here in the states.
McMaster-Carr
If you narrow by "wood" and "grooved and barbed" on the left side of the page the ones I like best are the second on the list. No adhesive needed.
Found these guys - Threaded Inserts
Hope you find what you need.
GCG
GulfcoastGuy is offline
post #4 of 23 (permalink) Old 08-31-2012, 09:05 AM
Honored Member
harrysin's Avatar
First Name: Harry
Originally Posted by Gaia View Post
Hi all,
Cheers guys,
Pete.
Peter, I've used lots and lots of Tee nuts and never needed to use any adhesive, the four prongs and a tight hole being sufficient.
Evo-Stick, now that rings a bell, that was the first contact adhesive that came on the market in England around 1950.
Harry
harrysin is online now
post #5 of 23 (permalink) Old 08-31-2012, 09:50 AM
CharleyL's Avatar
First Name: Charley
I've never felt that T nuts needed any glue if the hole for them is made the correct size. For repairs I've sometimes resorted to epoxy to hold the T nut in place when the hole around it has been damaged, but I've seen two occasions where people had used the T nuts incorrectly. They had inserted the T nuts on the wrong side of the board and, of course, they pulled right out. T nuts have to be installed from the back side of the board so the pulling force pulls the T nut deeper into the hole. The prongs need to point toward the direction of the pulling force. They serve to anchor the nut and also prevent it from turning.
Charley
Central North Carolina
CharleyL is online now
post #6 of 23 (permalink) Old 08-31-2012, 10:20 AM Thread Starter
Gaia's Avatar
First Name: Peter
OK thanks John.
Gaia is offline
post #7 of 23 (permalink) Old 08-31-2012, 10:22 AM Thread Starter
Gaia's Avatar
First Name: Peter
McMaster-Carr
GCG
Thanks, for the UK link, Mcmaster, didn't realise, such a range of types of threaded inserts.
Gaia is offline
post #8 of 23 (permalink) Old 08-31-2012, 10:27 AM Thread Starter
Gaia's Avatar
First Name: Peter
OK thanks Harry, would no glue also apply to M6 pronged T nuts used in making knobs for the jigs?
Cheers.
Gaia is offline
post #9 of 23 (permalink) Old 08-31-2012, 10:34 AM
Honored Member
harrysin's Avatar
First Name: Harry
Sure, so long as they are on the correct side of the knob, the outside so that they pull tight as the knob is tensioned.
Harry
post #10 of 23 (permalink) Old 08-31-2012, 10:38 AM Thread Starter
Gaia's Avatar
First Name: Peter
I'm with you, thanks
Gaia is offline
Using Barrel Nuts In MDF Jig Gaia Jigs and Fixtures 15 06-19-2012 05:17 PM
MDF Stability for Kitchen Doors slennon DIY and Renovation 10 03-16-2012 02:11 AM
Glue advice Router is still my name Tools and Woodworking 17 10-08-2006 11:18 AM
Best glue chioce for MDF Router is still my name The Finishing Touch 6 07-15-2006 03:24 AM
