Homemade router lift - Router Forums
post #1 of 4 (permalink) Old 09-14-2012, 05:18 PM Thread Starter
JOAT's Avatar
First Name: Theo
Default Homemade router lift
Just found this on youtube, looking for I can't remember what. Very slick. Very simple. And it works.
Router Lift - YouTube
And this looks like how it is operated. http://www.youtube.com/watch?v=c6wb9...feature=relmfu If you can't make your own version, from these two videos, then I don't know what to say.
Plans? Plans? We don' need no steenkin plans.
JOAT is online now
post #2 of 4 (permalink) Old 09-15-2012, 07:55 AM
First Name: Don
I just completed a router lift. My plunge router has an irregular profile, so creating a cradle for it was frustrating. I gave up on designs that are built around a model similar to the one Joat posted. I bought a couple of heavy-duty ball-bearing drawer slides. These could be held to the router using small bolts through the handle-mounting holes (I obviously removed the handles). Using wooden shims and some sheet-metal strips, I created a way of sandwiching the lower (when inverted) end of the router so the axis of the bit would be held parallel to the movement of the slide. Then I built a frame with couple of wooden supports to attach the outer parts of the slide perpendicular to the underside of the table. This allows me to remove the entire mounting plate to change bits so there's plenty of room.
The device lifts using a 1/2" threaded rod with a nut embedded in a piece of wood attached to the router-slide assembly. That is turned by a crank assembly salvaged from a seed-spreader a friend was throwing out. the crank axis is 90 degrees to the axis of the threaded rod. This is mounted on a "floor" made of a wider piece of plywood held by the frame. The whole thing looks ugly, but works great, and since the gear ratio allows the bit to rise 1" for a complete revolution of the crank, adjustment is a breeze. The whole thing cost under $20, since the spreader was free.
friendly1too is offline
post #3 of 4 (permalink) Old 09-15-2012, 09:23 AM
RouterForums.com User
harrysin's Avatar
First Name: Harry
And this looks like how it is operated. Router Table 1 - YouTube If you can't make your own version, from these two videos, then I don't know what to say.
Here is yet another method. I based this one on a design by late member Niki., whose version was made from a few sticks and rubber bands but worked perfectly.
Harry
harrysin is offline
post #4 of 4 (permalink) Old 09-26-2012, 10:00 PM
TenGees's Avatar
First Name: Paul
Originally Posted by harrysin View Post
...Niki., whose version was made from a few sticks and rubber bands...
Correct me if I'm wrong but it looks like your using a roll of string instead of the elastics.
Just kidding Harry, excellent looking set-up.
TenGees is offline
Making a Flat-Bottomed Candy Dish using a Router learnexperience Table-mounted Routing 2 12-09-2018 08:51 AM
Getting Started With A Woodworking Router. learnexperience Table-mounted Routing 9 10-22-2014 06:43 PM
Using Your Router For The First Time learnexperience General Routing 0 07-23-2011 09:20 PM
