Tenon Rounding Jig - Router Forums
post #1 of 10 (permalink) Old 09-21-2012, 02:16 PM Thread Starter
Gaia's Avatar
First Name: Peter
Default Tenon Rounding Jig
I want to make some chisel handles. I need to round off the handle to accept the ferrule. Mike on the forum said to use a tenon rounding jig for the handle shoulders. I Googled but couldn't really find anything, couple of articles refered to using a dado blade on a tablesaw. My tablesaw can't take dado blades. I have a router in a table and a drill press. I also read about tapering the shoulder so the ferrule will tighten up when it fitted. I searched the jig forum here but no leads.
Thanks.
Gaia is offline
post #2 of 10 (permalink) Old 09-21-2012, 02:27 PM
First Name: Chris
how about using a round off bit in the table?
Chris Curl is offline
post #3 of 10 (permalink) Old 09-21-2012, 02:31 PM
giradman's Avatar
First Name: Dave
Plug & tenon cutters would be an option - just bought me the set below from Lee Valley HERE - if you just need 1 or 2 sizes, they can be purchased individually. Also I've seen a simple router table jig on a Woodsmith video (not sure how long you need the round tenons to be but might be an issue?) - checkout the podcast HERE - good luck! Dave
giradman is offline
post #4 of 10 (permalink) Old 09-22-2012, 06:59 AM
First Name: Art
Without a lathe I would use the drill press. Cut the wood longer than needed and rough it down so that you can chuck it up in the drill press and rough the other end down so it is somewhat the size you need. Then turn on the drill press as slow as it will go and hold a rasp against the end of the wood until it is the size you want. Ferrules can be made out of copper pipe couplings.
mgmine is offline
post #5 of 10 (permalink) Old 09-22-2012, 07:59 AM
Here are a couple photos of one method. I have been thinking about building this jig and I will post photos if I do.
Name:	Round tenon jig1.JPG
Name:	Round tenon jig2.JPG
post #6 of 10 (permalink) Old 09-24-2012, 08:31 AM
Bradleytavares's Avatar
First Name: Bradley
If you place your (square ?) piece in a piece of close fitting plastic tube, tube in sled or miter gauge, raise TS blade and push just the edge of the piece over the top of the blade and slide the piece left and right over the blade as you nibble the corners off till you have a round tenon. Continue nibbiling and sneaking up on the tenon till it's the correct size. Works great, learned this receintly from a guy who's older than most of us.
Bradleytavares is offline
post #7 of 10 (permalink) Old 09-24-2012, 09:03 AM Thread Starter
Gaia's Avatar
First Name: Peter
Thanks, not that expensive either.
Gaia is offline
post #8 of 10 (permalink) Old 09-24-2012, 09:11 AM Thread Starter
Gaia's Avatar
First Name: Peter
Originally Posted by mike View Post
here are a couple photos of one method. I have been thinking about building this jig and i will post photos if i do.
ok.
Gaia is offline
post #9 of 10 (permalink) Old 09-24-2012, 09:12 AM Thread Starter
Gaia's Avatar
First Name: Peter
OK thanks.
Gaia is offline
post #10 of 10 (permalink) Old 09-24-2012, 09:13 AM Thread Starter
Gaia's Avatar
First Name: Peter
Originally Posted by bradleytavares View Post
if you place your (square ?) piece in a piece of close fitting plastic tube, tube in sled or miter gauge, raise ts blade and push just the edge of the piece over the top of the blade and slide the piece left and right over the blade as you nibble the corners off till you have a round tenon. Continue nibbiling and sneaking up on the tenon till it's the correct size. Works great, learned this receintly from a guy who's older than most of us.
ok.
Gaia is offline
For Sale: F/S Leigh FMT Jig - Cut Precise Mortise & Tenon Joints With Your Router Paul Joynes Woodworking Classifieds 5 06-06-2012 08:15 AM
mortise & tenon jig yairfe Jigs and Fixtures 23 10-21-2009 05:49 PM
