Guide bushing or guide bearing??? - Router Forums
post #1 of 9 (permalink) Old 09-23-2012, 05:35 PM Thread Starter
First Name: Ger
Question Guide bushing or guide bearing???
I am looking at dovetail jigs and I see some have guide bushings and some have guide bearings. I have narrowed it down to a PC 4216 (bushings) or a Keller (guide bearings). I am interested in the capability to make small boxes which the PC has but working on a router table would also be nice.
What are the pros and cons????
Ger
argentum is offline
post #2 of 9 (permalink) Old 09-24-2012, 08:16 AM
Ger, unless your heart is set on making dovetails I would suggest you start with box joints. This makes a nice strong decorative joint and has a much easier learning curve. Besides being easier it is also much faster.
post #3 of 9 (permalink) Old 09-24-2012, 09:54 AM
First Name: Gerry
Guide bearings are very handy, but do have the problem of sometimes coming off. Guide bushings are very simple, and almost indestructable. I have used both, and have to say that I do like the convenience of using the bearings. For table top routing I would probably be inclined to go with bearings.
Gerry
Gerry Kiernan is offline
post #4 of 9 (permalink) Old 09-24-2012, 10:39 AM
Maroonram's Avatar
First Name: Bob
I have never used anything but guide bushings and have never had a problem.
Maroonram is offline
post #5 of 9 (permalink) Old 09-24-2012, 11:05 AM
JOAT's Avatar
First Name: Theo
I used to have that problem too. Then I found that putting a drop or two on the bearing before each routing session makes the bearing seem to last forever. I've several years of use on my latest bearing.
JOAT is offline
post #6 of 9 (permalink) Old 10-01-2012, 08:58 AM
First Name: Gerry
Thanks for the tip.
Gerry
post #7 of 9 (permalink) Old 10-01-2012, 09:42 PM Thread Starter
First Name: Ger
Default Guide bushing or bearing
Thanks guys I settled for the PC 4216.
Your input is much appreciated.
Ger
argentum is offline
post #8 of 9 (permalink) Old 10-08-2012, 04:46 AM
JOAT's Avatar
First Name: Theo
Dad burn it, that was supposed to read 'a drop or two of oil'.
JOAT is offline
post #9 of 9 (permalink) Old 10-08-2012, 05:53 AM
Gene Howe's Avatar
First Name: Gene
Glad you cleared that up.
Gene Howe
Snowflake, AZ
Gene Howe is offline
Guide bushing identification Mike Guide Bushings and Templates 42 09-22-2013 08:25 PM
Guide bushing fabrication johnpaulh Guide Bushings and Templates 10 01-30-2012 06:32 AM
Dewalt DW625E Guide Bushing adapter plate accepts standard bushing rchlyosi General Routing 3 11-11-2011 02:56 PM
Bit not centered in guide bushing RonH Guide Bushings and Templates 14 05-01-2009 12:41 PM
Router template inlay V Garry General Routing 7 12-27-2008 06:49 PM
