Table saw dust control - Router Forums
post #1 of 13 (permalink) Old 10-09-2012, 12:03 AM Thread Starter
First Name: Chris
Default Table saw dust control
My table saw, an older basic Skil 3400, has no dust control features built in. This table is completely open under the saw. Over time, it has become clear that pretty much all of the dust it generates is carried by the blade under the table. So I have started making a dust catcher.
It is made out of materials I found in the garage: a piece of 12mm ply, some paint stirrers (of course!) ripped to 12mm, an old piece of canvas left over from a long abandoned project, and some pipe from my stalled thein dust collector project.
Pic 1: mock up from the front
Pic 2: from the back
Pic 3: the back piece with the canvas attached and hole for shop vac
Pic 4: the piping
Pic 5: connected
Pic 6: from the inside
With luck, this will pretty much eliminate the dust problem from my table saw.
Chris Curl is offline
post #2 of 13 (permalink) Old 10-09-2012, 05:10 AM
japa62's Avatar
Thanx's for that. Been debating if I should do it to my GMC TS. You have convinced me. Added to the ever growing todo board. Interested why you used canvas in the design.
Under construction, always.
japa62 is offline
post #3 of 13 (permalink) Old 10-09-2012, 07:17 AM
cagenuts's Avatar
Country: South Africa
First Name: Hilton
Send a message via Skype™ to cagenuts
Fine WoodWorking had an article on dust control for the Table Saw a couple of years ago. I have the magazine at home but I think it was issue #205.
It's really worth taking a look at the article as there is more to dust control than simply channelling the nasties to a bag in the corner.
cagenuts is offline
post #4 of 13 (permalink) Old 10-09-2012, 08:57 AM Thread Starter
First Name: Chris
James, I used canvas because that is what was in the garage.
Hilton, thanks for the link. Did you do the project, or have you done something for dust control on your saw? I'd be very interested to see what other people have done.
post #5 of 13 (permalink) Old 10-09-2012, 09:24 AM
giradman's Avatar
First Name: Dave
Hi Chris - will be anxious to see how well your solution works on the TS - good luck!
Earlier this year, I purchased a new TS (Steel City hybrid below) - has an enclosed cabinet w/ a 4" hose in the bottom center which is connected to my 1.5 hp dust collector; does a good job, but there is still an issue of above the table dust production, especially if using a ZCI, as I do - I'm trying to address that now.
Will be interested in others' responses on this issue - my bencktop Makita planer & chop saw are other machines that present dust collection issues! Dave
giradman is offline
post #6 of 13 (permalink) Old 10-09-2012, 09:33 AM Thread Starter
First Name: Chris
Thanks Dave. ZCI ... zero clearance insert? Mine does not have one of those.
Re the chop saw, I read somewhere that a cabinet with a hood and an enclosed section below addresses that well. IIRC, I think it was bobj3 who said that.
post #7 of 13 (permalink) Old 10-09-2012, 09:37 AM
giradman's Avatar
First Name: Dave
Yep - Zero Clearance Insert - I make my own - although I've not really tested the insert that came w/ the saw (the usual more open one to permit blade tilt), I suspect more dust will be sucked down w/ the larger opening, but then one loses the advantages of a ZCI - a trade off, I guess? Dave
giradman is offline
post #8 of 13 (permalink) Old 10-09-2012, 12:46 PM
BrianS's Avatar
First Name: Brian
Nice job Chris. I made a similar one for my Dad's old contractor's saw a while back and it did a pretty good job. Mine was just flat bottomed.. I think yours going into a V would do a better job. I never made a ZC insert for it, but I don't think it makes much difference with, or without, a ZC insert as far as dust collection goes. A lot of the sawdust collects in the gullet of the blade and is swept underneath as the blade revolves.
I now have a Rigid(R4511) hybrid saw with an enclosed cabinet, similar to Dave's, and have made a ZC for it. With the stock insert, or the ZC that I made, it doesn't seem to make a lot of difference in the sawdust in the air.
I've seen several different designs for over-the-table dust collection, but never tried any. A simple hood suspended over the blade seems to be the most common theme. I just resigned myself to the fact that it is impossible to catch ALL the sawdust and just wear a good dust mask.
Brian
(Origin uncertain)
BrianS is offline
post #9 of 13 (permalink) Old 10-09-2012, 01:53 PM Thread Starter
First Name: Chris
thanks brian.
confession time ... my original plan was just to have a hole that the hose connected to directly. but i used the wrong hole saw (too big) for it. that is why it has all that seemingly unnecessary piping.
sigh
post #10 of 13 (permalink) Old 10-09-2012, 03:37 PM
OPG3's Avatar
First Name: Otis
Chris, I have a neighbor who is retired, but still does some furniture refinishing. He has a small table saw mounted on a stand as you have pictured. He cut 4- tapering boards that form a "funnel" and collects most of his sawdust quite nicely with that. The bottom of his funnel is open - about 3 inches square - so his sawdust just falls into a five gallon bucket below. Simple, yet effective. If you were to adopt this method, you could use 1/4" thick MDF - the slick sides will transfer dust easier than a canvas surface. If I were to make one of those, at least one side would be plexiglas; or something transparent. Good luck!
OPG3
Tweak everything!
OPG3 is offline
Control Box for HF 2HP Dust Collector JohnnyB60 General Routing 5 05-12-2012 05:46 PM
Dust control xplorx4 Tools and Woodworking 35 03-19-2012 10:40 AM
dust collection/cooling in enclosed table ascerin Table-mounted Routing 10 04-03-2011 05:30 PM
New Fence and Dust control? rolanddds Table-mounted Routing 10 01-26-2010 09:20 AM
Dust Control and Router Cabinet? rolanddds Table-mounted Routing 5 10-04-2009 01:02 PM
