Minimizing the waves from a router sled - Router Forums
post #1 of 13 (permalink) Old 10-10-2012, 12:33 AM Thread Starter
MaxK's Avatar
First Name: Max
Default Minimizing the waves from a router sled
So, after determining that the width of skis I need would require a larger diameter rod than 9mm, and that My router base was laid out in a way that prevents me from just drilling the holes larger, I set about building a plywood sled as seen in many a "how to flatting your end grain cutting board/workbench" youtube video. Bar a sloppy slot which I will be enlarging a hair and cleaning up when my template bit gets here, I'm pretty pleased with myself lol.
Anyways, I am building an electric bass body, and am planing the blank flat (It's made from 3 pieces of hard white ash). I'm using a 1 1/4" mortising flat bottom bit from Freud to do the cutting. At the thickest point, I'll be taking out just shy of 1/8" of material. I've gotten about 1/4 of the way across the blank, and the waves where one cut leads to the next are a bit bigger than anticipated. Maybe 1/4 to 1/2 mm? Is that roughly what one would expect, or is that bigger than normal?
If it is bigger than normal, what would cause that? The only thing i could think of is if my routers base plate was not perpendicular to the cutting bit somehow. Am I missing something obvious here? I would post pics of the whole thing, but I'm a few posts away from there yet. Thanks in advance guys
MaxK is offline
post #2 of 13 (permalink) Old 10-10-2012, 12:40 AM
First Name: Chris
sounds like the bit is not quite perdendicular to the wood.
the more perpendicular the bit is to the wood, the smaller the waves should be.
Chris Curl is offline
post #3 of 13 (permalink) Old 10-10-2012, 01:04 AM Thread Starter
MaxK's Avatar
First Name: Max
Forgive me if I misunderstand the whole process lol. Why would the surface of the wood pre -routing affect the plane of the wood post-routing? I've checked to the best of my ability that tops of my rails as well as the surface of my sled are all coplanar, and as far as i can tell theyre pretty darned close.
In the meantime, I've found that by routing moving the sled along the rails, then moving the router in the sled a bit and starting over, I get much fewer lines than if i route along the sled, move the sled a bit on the rails, and repeat. Is there anything wrong with this approach?
MaxK is offline
post #4 of 13 (permalink) Old 10-10-2012, 05:58 AM
RouterForums.com User
harrysin's Avatar
First Name: Harry
I'm sure that it's as Chris has said. This is a problem that I encountered and wrote about the first time that I used a 1 3/4" bottom cleaning bit. I hadn't ensured that the height of the ski rods was identical in all four corners, the result was that the cut was a fraction deeper on the left side prodicing a surface that if magnified would have resembled a saw-tooth. Once the skis were accurately set-up the results were perfect.
Harry
harrysin is offline
post #5 of 13 (permalink) Old 10-10-2012, 08:05 AM
First Name: Eloy
Howdy Max,
Harry is absolutly right, you must have the router set up perpendicular to your work but if you have slop in your setup you could minimize it by tensioning your setup with a couple of springs set at 20 degrees off parallel out to keep your router from rocking in the cut. I.E. tension the slop out of your setup and you will improve your results.
Good Luck,
-Eloy
damnitboy is offline
post #6 of 13 (permalink) Old 10-10-2012, 10:02 AM Thread Starter
MaxK's Avatar
First Name: Max
I think I originally misunderstood. Yeah if one or more for corners of the railing aren't coplanar that would cause the surface being routed to not come out flat. I don't know why that didn't click last night.
I also do have plenty of slop. I may have over waxed the rails that the sled sits on. It might be a little TOO easy to slide the sled along the rails.
In better news, this is my first piece of joined wood (simply edge joined) with a power jointer or otherwise, and where I've flattened it the glue line is only visible to due the grain changes. Its a super tight seam. At least something is going smoothly lol.
MaxK is offline
post #7 of 13 (permalink) Old 10-10-2012, 08:21 PM Thread Starter
MaxK's Avatar
First Name: Max
It just needed a hair more downward pressure to keep the router flat in the sled, and it is much better.
Unfortunately, I slipped and knocked the sled off one edge, and it gouged the piece. I can salvage it for something else quite easily, but not for this. This is why you learn on inexpensive woods like ash and such, I suppose.
MaxK is offline
post #8 of 13 (permalink) Old 10-10-2012, 11:19 PM Thread Starter
MaxK's Avatar
First Name: Max
Well, upon busting out a precision straight edge and a set of calipers, the 4 corners of my rails are out of plane from the base by up to half a mm from the lowest to the highest point, and while i flattened the blank (the top and bottom sides both came out amazingly smooth, once i started adding a hair of pressure and scraped off some excess wax, to the point where theres very little light that makes it under a straight edge), it's not of a uniform thickness, by a difference of around 2.75 mm or so between the thinnest and thickest sections. Is the offset in the rails height enough to cause that much variance?
I may need to pick up another router and make some adjustable skis. I can take a good 7 or 8 mm off and still find a use for the blank, so I can keep adjusting and taking off miniscule amounts.
Here you can see the sled (I'll link it, since it's large)
http://www.8bytealchemy.com/wp-conte...9-1024x768.jpg
and here is its construction (and use)
Building a Sled and Planing the Blank | 8 Byte Alchemy
MaxK is offline
post #9 of 13 (permalink) Old 10-10-2012, 11:40 PM
Max, the easiest way I have found to level both of the plywood ski jigs shown is to have the H frame level on your work surface and tighten the wing nuts/knobs. Once this is square then place a block measuring 1 x 2 x 3" under two diagonal corners of the H frame where it supports the router. (I use an inexpensive pair of steel 1,2,3 blocks for this) Tighten the wing nuts/knobs on the risers and you will get level cuts.
post #10 of 13 (permalink) Old 10-11-2012, 12:17 AM Thread Starter
MaxK's Avatar
First Name: Max
Yeah, I'm going to try to knock my rails flat with a hand plane, and if that doesn't work, I'll build an adjustable sled like those. In the mean time, one of my good friends it turns out has a 2 piece blank ready to go that just needs to be edge jointed. I think I'm going to step away from the project for a day or so, before I start getting frustrated lol.
MaxK is offline
router planing sled d-gilb1950 General Routing 8 01-12-2012 05:53 PM
Using Your Router For The First Time learnexperience General Routing 0 07-23-2011 09:20 PM
VIDEO - Shop built Mitering and Crosscut Sled johnwnixon Tools and Woodworking 5 09-06-2009 10:14 AM
Using Bill Hylton's router sled loninappleton Jigs and Fixtures 0 02-20-2009 11:04 PM
