Depth gauge jig - Router Forums
post #1 of 31 (permalink) Old 10-10-2012, 10:40 PM Thread Starter
MT Stringer's Avatar
Default Depth gauge jig
I did a fair amount of handheld routing today cutting dadoes and rabbits in some oak plywood that will eventually become two benches with three cubbies each.
One thing that bugs the heck out of me is setting the depth stop on my plunge router. For some reason, I wrestle with it every time and it wins most of the time. Maybe I am just a wimp, but I have a hard time getting the depth just right while working against the springs.
So, come tomorrow, I plan to do some jig building and create a board with some of my favorite depth settings. That way I should be able to just sit the router over the appropriate dept and plunge it until it bottoms out. If I was after 3/8 inch, it should be right on the mark. Of course my jig will only be as good as my accuracy setting it up. I will figure that out when the time comes. May have to use a forstner bit and carefully drill each depth setting.
I will post up my handiwork.
MT Stringer is offline
post #2 of 31 (permalink) Old 10-10-2012, 11:12 PM
Hi Mike - not sure what kind of problem you're having. "working against the springs". I just loosen the plunge rod and plunge mine down to the top of the work surface and lock it. I then just put a spacer equal to the depth I want between the plunge rod and turret and lock the stop rod in that position.
John Schaben
jschaben is offline
post #3 of 31 (permalink) Old 10-11-2012, 08:23 AM
First Name: Duane
Mike, after watching one of Bob Rosendahl's live router demos 17 or 18 years ago, I went out the same day and bought a set of brass setup bars. They can't be beat for accurate standard size(1/8, 3/16, 1/4,3/8,1/2) setups or any combination of those sizes stacked! Most plywood dados I do are either 1/4" or 3/8" so makes it very easy to do as John suggested. I am still using that same set of setup bars today!
Dmeadows is offline
post #4 of 31 (permalink) Old 10-11-2012, 09:08 AM
paduke's Avatar
Those little brass bars and playing cards are my preferred set up tools as well. I use my fingers to see.
paduke is offline
post #5 of 31 (permalink) Old 10-11-2012, 09:15 AM
cagenuts's Avatar
Country: South Africa
First Name: Hilton
Send a message via Skype™ to cagenuts
Or just bottom the bit out on a flat surface, then zero out the depth guide and adjust accordingly.
cagenuts is offline
post #6 of 31 (permalink) Old 10-11-2012, 09:45 AM
First Name: Chris
i m going to harbor freight today for a couple more clamps. i'm going to pick up a set of these too
Chris Curl is offline
post #7 of 31 (permalink) Old 10-11-2012, 10:14 AM
First Name: Ben
By all means get a set of brass set-up bars. In the meantime use the thickness of your drill bits to set the plunge depth. If necessary use playing cards for fine adjustments.
Ben
Forest Reduction Study Group
Ben in Cypress Texas is offline
post #8 of 31 (permalink) Old 10-11-2012, 11:09 AM Thread Starter
Well, where has my head been? I will give that a shot. DUH!
Thanks for the tips.
post #9 of 31 (permalink) Old 10-11-2012, 11:45 AM
Mike;
42 years of woodworking experience?
Just asking...
giltic is offline
post #10 of 31 (permalink) Old 10-11-2012, 11:52 AM Thread Starter
Originally Posted by giltic View Post
Mike;
Just asking...
Yep...about 40 of those was off and on using 2x4's! :-)
Never too late to learn something new.
Porter Cable 55160 Omnijig Review Echonav Tool Reviews 19 06-21-2015 03:59 AM
Shelf pin hole jig - reviews and router solution Greg_R Jigs and Fixtures 17 04-24-2014 09:02 PM
EZ Dovetail Jig bobj3 Jigs and Fixtures 7 04-02-2014 08:43 PM
Akeda BC24 Dovetail Jig arrived! Michael H Jigs and Fixtures 13 04-11-2012 10:50 PM
Hinge mortising question Dalec Jigs and Fixtures 8 03-02-2009 07:17 AM
