How to make a circle (no center hole) - Router Forums
post #1 of 16 (permalink) Old 10-11-2012, 01:43 AM Thread Starter
Country: Denmark
First Name: Torben
Default How to make a circle (no center hole)
I have a small task: make a cover of an access hole in my kayak, since I lost the original rubber cover. My idea is to make it from clear plastic, since the hole rim has threads for screws.
I think the router could do the job.
Finding a circle jig is not really an issue: just drill a hole and rotate tool around it. But.. since this is for water-use, drilling a hole is a bad idea.
So any nice tips on how to avoid this center hole ? I would like to have a perfect circle at the end.
FYI: my workshop is very small, and I only have a std. plunge type router for the job.
myicq is offline
post #2 of 16 (permalink) Old 10-11-2012, 01:51 AM
Torben; how about simply making a template then using it as a pattern? A ctr. hole in the template won't matter.
DaninVan is offline
post #3 of 16 (permalink) Old 10-11-2012, 02:26 AM
japa62's Avatar
Yep, a pattern double sided taped down.
Under construction, always.
japa62 is offline
post #4 of 16 (permalink) Old 10-11-2012, 06:10 AM
First Name: Andy
You don't necessarily need a hole all the way through to use a circle jig, if the piece is thick enough to accommodate a blind hole. If not the pattern idea sounds nice and simple.
AndyL is offline
post #5 of 16 (permalink) Old 10-11-2012, 06:43 AM
First Name: N/a dave
Default making a hole
hi,have you tried double sticky sided tape make a template stick it on the plastic and run the router round and peel it off dave northyorks uk
davewilson is offline
post #6 of 16 (permalink) Old 10-11-2012, 07:30 AM
First Name: Art
use a hole saw and cut a hole in a piece of 3/4 in stock. Then take the drill bit out of the hole saw and use the piece you cut out of wood as a guide. Place the piece on the part you want to cut so that the bitless (is this a word?) hole saw won't wander around.
mgmine is offline
post #7 of 16 (permalink) Old 10-11-2012, 08:19 AM
cagenuts's Avatar
Country: South Africa
First Name: Hilton
Send a message via Skype™ to cagenuts
Isn't Guy Fawkes coming up soon?
Just thinking in case you don't get the circle cut :-)
cagenuts is offline
post #8 of 16 (permalink) Old 10-11-2012, 08:48 AM
harrysin's Avatar
First Name: Harry
Rout a hole in a piece of MDF etc using a router circle jig then sit this on top of your material and, using a template guide and straight bit route your disk.
To calculate the diameter of the hole in the template the simple formula is:
template guide dia. - bit dia. + size of wanted disk.
Suppose that you require a 6" disk and decide to use a 1" template guide and a 1/4" bit, then: 1"-1/4"+6"=6 3/4" hole in the template. It really is that simple.
Harry
harrysin is online now
post #9 of 16 (permalink) Old 10-11-2012, 10:21 AM
Wood Chip's Avatar
First Name: Gary
You can always use a template to rout a circle, but would a hole really be such a problem? If the lid is going to be solid, why not use the hole to secure a handle? or a rod-holder? or a cleat?
Wood Chip is offline
post #10 of 16 (permalink) Old 10-11-2012, 11:03 AM
First Name: Richard
Send a message via Skype™ to rwbaker
Take the easy way out and use a suction cup that has a long hook that can be formed to a pin and circle away.
rwbaker is offline
MLCS Circle Jig larryc Table-mounted Routing 3 01-30-2012 10:44 PM
Router Plate Installation Rutabagared Project Plans and How To 11 01-14-2012 07:15 PM
How to Make a Simple Clock Using Box Joints learnexperience Tools and Woodworking 2 08-15-2011 09:21 AM
How To Make a Box with a Box Joint learnexperience General Routing 7 08-07-2011 07:07 AM
base plate for mortising? How make it? help Bogydave Jigs and Fixtures 12 11-17-2008 02:15 PM
