Need advise/ideas on box trays - Router Forums
post #1 of 4 (permalink) Old 10-12-2012, 11:24 AM Thread Starter
SteveMI's Avatar
First Name: Steve
Default Need advise/ideas on box trays
I am making boxes that are 6*6*3 and 5*9*5 with inlay in the tops. All is well in the making of the boxes.
I need to make trays to go in the boxes. I'd like to use the thinnest wood practical to keep the most space inside available, less than 1/4". Simple 45 degree bevels seem too weak and that thin of stock leaves out the lock joint bits. Being only 2" tall, using a box joint jig seems overkill and holding the shorter sides could be a bit tricky. I got the MLCS box joint bit and it is working all right.
What are the other options?
Steve.
SteveMI is offline
post #2 of 4 (permalink) Old 10-12-2012, 11:47 AM
First Name: Ben
I have a mental picture of your problem, it might not be correct. So please bare with me. I'm picturing open top three sided boxes and you wanting to put in thin dividers.
Further I assume that you haven't glued up your boxes. If so take a piece of scrap and cut a groove in it on your table saw trial fit your divider material in the groove. If you have a dado set adjust your groove width to fit your divider material. Disassemble your boxes and groove the inside to accept the dividers. Dry fit the complete assembly before glue up.
Ben
Forest Reduction Study Group
Ben in Cypress Texas is offline
post #3 of 4 (permalink) Old 10-12-2012, 11:49 AM
If you have a 1/8" bit you can make locking rabbit joints or use butt joints with glue and pin nails. Sawdust Saturday here on the 27th, come join us and we will build some.
post #4 of 4 (permalink) Old 10-12-2012, 12:22 PM Thread Starter
SteveMI's Avatar
First Name: Steve
Ben - These are four sided boxes, 6 inch square by 3 inch tall, 5 inch tall, 5 inch deep and 9 inches wide. I'm not adventurous enough for a three sided box.
Mike - I am going to plan on being there. Not so interested in the butt joints, but the locking rabbit seem like a potential. PM me the address.
Steve.
SteveMI is offline
My first box dkneifel Show N' Tell 19 02-08-2016 08:10 AM
box corner joinery almost there Jigs and Fixtures 17 10-15-2012 08:08 AM
Learning How to Make a Tissue Box Cover learnexperience General Routing 2 12-05-2011 05:56 PM
Another combination plane blade box hack rwyoung Show N' Tell 8 01-10-2011 08:41 PM
Beall Tilt Box Versus Wixey Angle Gauge bennybbc Tool Reviews 4 02-04-2010 12:01 PM
