Clamping Techniques - Router Forums
post #1 of 7 (permalink) Old 11-03-2012, 10:00 PM Thread Starter
JOAT's Avatar
First Name: Theo
Default Clamping Techniques
Just ran across this. Looks like it would be a great timesaver for some of the things I do. However, the price of those clamps precludes buying any. So for now at least I'm pretty much sticking with my tried and true method of holding my piece to be routed in place with nails. Ah well. Woodworkers Journal : Clamping Techniques : Five Practical Applications for Toggle Clamps
However, it does give me thoughts of a new use for cam clamps. Will have to think on that, but may be able to come up with something out of just scrap wood. I made some nice cam clamps out of plywood, no reason I can't make some for a different use.
JOAT is online now
post #2 of 7 (permalink) Old 11-03-2012, 10:30 PM
Theo, HF offers toggle clamps that are a useful size on most jigs for $6? each.
post #3 of 7 (permalink) Old 11-03-2012, 10:49 PM
paduke's Avatar
I get my togglers from harbor freight I also purchase longer spindles from grainger
Toggle - Harbor Freight Tools clamp
DE-STA-CO Flat Tip Spindle, 1/4-20, 0.63, 2.13 - Toggle Clamp Spindle Assemblies - 3CWY7|215208 - Grainger Industrial Supply
I use them everywhere. Here is a clamping table I made and use toggle clamps on
http://www.routerforums.com/tools-wo...ing-table.html
paduke is offline
post #4 of 7 (permalink) Old 11-03-2012, 10:53 PM
Hi Theo - quite possibly the most used jig/fixture I have made since I joined this forum is a cam board. Very handy for a lot of applications. Try a search, I'm sure there are a lot of threads on it.
These are great when doing surface or edge work with hand held mode. You can raise the stock off the board by using thinner cams, stacked and rotate the bottom cam under the workpiece to raise it off the board.
Name:	cam board 1.JPG
Name:	cam board 2.JPG
John Schaben
jschaben is offline
post #5 of 7 (permalink) Old 11-04-2012, 01:53 AM
First Name: Chris
i got some at harbor freight and they were not very expensive at all
Chris Curl is offline
post #6 of 7 (permalink) Old 11-04-2012, 02:14 PM Thread Starter
JOAT's Avatar
First Name: Theo
Thanks guys. Looks like HF is a way to go. But even at $6 a pop, I would need seven of them just for my chess set, six for the various pieces, and one for the base. That's $42, less tax and gas money, for just that project. Adds up fast. Plus a new router bit.
JOAT is online now
post #7 of 7 (permalink) Old 11-04-2012, 03:49 PM
papawd's Avatar
First Name: warren
Yes it will add up fast theo, but then you will have new toys for later projects
papawd is offline
Clamping Table paduke Tools and Woodworking 10 07-22-2014 06:30 PM
Routing Tips and Techniques John Davitt New Member Introductions 1 08-14-2011 12:26 AM
Vacuum Clamping woodapple Jigs and Fixtures 19 12-09-2008 12:00 PM
Introduction/ Decline Cutting Techniques gdrumz New Member Introductions 8 03-15-2008 04:36 AM
Routing Tips and Techniques template tom Portable Routing 15 01-04-2006 03:52 AM
