Hello, and Craftsman 25790 info - Router Forums
post #1 of 3 (permalink) Old 11-23-2012, 09:11 AM Thread Starter
First Name: Ken
Default Hello, and Craftsman 25790 info
Hi all,
I'm new to this forum. Read a lot of threads and it sounds like you're a great bunch of folks so I decided to join. BTW, happy belated Thanksgiving to all.
I came across this group when I was doing a google search to locate a copy of a manual for my dovetail jig. I never did find the manual online, but I did find my own hardcopy. So, if any has a use for a copy of a manual for a craftsman 25790, let me know and I'll scan it and send it to you.
I also have a bunch of questions about dovetail jigs in general that I formed when trying to use my jig for the first time two days ago.
My first question is about the 25790. I swear I followed the instructins to a tee but found the dovetail came out wrong. In paricular, it seems the spacers which position the actual template are not correct. I attempted a half blind and found it cut into the front piece too far. I had to use additional washers to push the template out further so the joint would be correct. Anyone have any advice about this?
My second question is a little more generic. When i look at my directions for doing a rabbetted half blind, I have to do it in two steps, first the side piece and then the top piece. This is to give a chance to reposition the template backwrds so that the cut will be far enough back to compensate for the rabbett. It seems to me the process could be done in a single step if the fingers on the template were cut deeper, no? Are all jigs designed this way?
My third question is about bits. I understand that if you use a craftsman jig, you must use a craftsman bit. Is the same true for other brands or do they use some industry stndard?
Thats it for now. Any help would be appreciated. Thanks in advance.
bahaba is offline
post #2 of 3 (permalink) Old 11-23-2012, 10:20 AM
This may help
http://www.routerforums.com/jigs-fix...5-25710-a.html
and you can use any dovetail jig
Originally Posted by bahaba View Post
Hi all,
post #3 of 3 (permalink) Old 11-23-2012, 05:16 PM
Welcome to the forum, Ken.
Sydney, Australia
jw2170 is offline
