Large box joints - Router Forums
post #1 of 5 (permalink) Old 11-27-2012, 09:09 PM Thread Starter
First Name: Dean
Default Large box joints
Hello,
This is my first post to the router forum.
I am designing a filing cabinet about 4 feet hight by 12 inches deep by 14 inches wde. The 2 sides will have a "live edge" in the front.
What I would like to do is use large (like 2 inch wide) box joints to join the sides and back. The wood in question is relatively thin (about 5/8 inch thick) so I want the advantage of a true mechanical connection when I glue it all up. There are a couple of problems with this approach:
- the size of the boards themselves which are 12 inches by 4 feet in dimension
- If I make the joint using a table saw, the biggest dado I can take in one pass is 3/4 inch
So has anyone tried this? If so did you use a table saw, router table or a hand held router with a large home built router jig?
Looking forward to the group's collective wisdom.
Dean
lignumvitae is offline
post #2 of 5 (permalink) Old 11-27-2012, 10:16 PM
First Name: Earl
Hi Dean--welcome to the forum.
I've not even come close to that kind of project, but had a few thoughts as i read. Box joints are rectangular and offer more surface area for glue, but don't really add any other mechanical advantage. Angling them a little, 7-14 degrees for example, creates a dovetail which would add mechanical advantage.
How to do that?? I'm prejudiced because i've been cutting all of my dovetails with router and jig and now that the light bulb has come on for me--i'm itching to learn how to hand cut them. Your project might lend itself well to the strategic placement of groups of tails--3 or 4 tails, space, 3 or 4 tails, space, etc. Especially if there is some contrast is wood color (which the exposed grain would create on its own).
Tails could easily be shaped with a router and dovetail bit--the waste wood for the most part cut away with a band saw or jig saw to "close" then cut to the line with a guided straight bit. This is where our seasoned members step in for the tachnique, but as i read your idea i had a mental picture!! Can't wait to follow your project!!
greenacres2 is offline
post #3 of 5 (permalink) Old 11-27-2012, 10:50 PM
This may help
http://www.routerforums.com/jigs-fix...ox-joints.html
http://www.routerforums.com/jigs-fix...-template.html
Name:	big box jpints.jpg
post #4 of 5 (permalink) Old 11-27-2012, 11:10 PM
Welcome to the forum, Dean.
I would consider hand cutting fingers that wide.
Sydney, Australia
jw2170 is offline
post #5 of 5 (permalink) Old 11-28-2012, 07:06 AM
First Name: Art
Dean are you doing this strictly for mechanical connection or for a visual effect? If strictly mechanical I would suggest using a pocket hole jig. The joint will be very strong and the project can be done in hours not days.
mgmine is offline
box joints? mah New Member Introductions 6 12-30-2012 10:48 PM
Incra Ultra How-To (Box Joints + Other Stuff) Nickbee Show N' Tell 17 06-22-2009 12:42 PM
First Box Joints w/a Hart Design Jig Wild Rag Jigs and Fixtures 2 03-23-2009 08:54 AM
Scott Slinking Tools and Woodworking 3 01-21-2009 02:20 PM
