Running Wood Between Bit and Fence...? - Router Forums
post #1 of 42 (permalink) Old 12-05-2012, 05:16 PM Thread Starter
Nickp's Avatar
First Name: Nick
Default Running Wood Between Bit and Fence...?
I am facing a piece of molding and find that there won't be enough flat wood to run the wood on the outside of the bit. It seems that if I run the wood in the opposite direction I should be able to run it between the bit and the fence...
Should/shouldn't I...? Precautions...? Other ideas...?
Thanks in advance...Nick
Nickp is offline
post #2 of 42 (permalink) Old 12-05-2012, 05:38 PM
N'awlins77's Avatar
First Name: Lee
Check out this thread, Nick. That same question was just brought up! Short answer, DON'T DO IT!!
http://www.routerforums.com/table-mo...8700-safe.html
N'awlins77 is offline
post #3 of 42 (permalink) Old 12-05-2012, 05:48 PM
Nick, the wood will be the same size on either side of the bit so why do you feel this would make a difference? The answer is NO, you never trap the wood between the bit and the fence for an edge cut unless you want to test your health insurance.
Some more information is needed before we can suggest an alternate method.
post #4 of 42 (permalink) Old 12-05-2012, 06:40 PM
First Name: Drew
Attach it to a manageable sized piece that's taller than it with double sided carpet tape, stick another piece of scrap atop the backing piece which will ride along the fence, and run it through normally.
Drew Eckhardt is offline
post #5 of 42 (permalink) Old 12-05-2012, 06:45 PM
First Name: Chris
If you have a drill press, you could hook up one of these and run it between a fence and the drum.
That would be similar to your router based solution, but less likely to kill someone should things go awry.
Chris Curl is offline
post #6 of 42 (permalink) Old 12-05-2012, 07:10 PM
Picture here may help. Don't quite understand "enough flat wood".
Short answer is no, need more info to find the right answer.
John Schaben
jschaben is offline
post #7 of 42 (permalink) Old 12-05-2012, 09:26 PM
I am making a guess that there are no flats left at the edges. It's better, if you can, to leave a little bit of flat at the edges and cut them off after.
post #8 of 42 (permalink) Old 12-06-2012, 06:41 AM
First Name: Richard
Send a message via Skype™ to rwbaker
"Ditto" to everything that has been said - I have always said that the smartest man is the man that knows what he does not know?
rwbaker is offline
post #9 of 42 (permalink) Old 12-06-2012, 07:54 AM Thread Starter
Nickp's Avatar
First Name: Nick
Lesson learned...thank you all for sharing your wisdom...and the additional thread info...especially for a better way to do it. Using another piece of wood to give the needed surface area will work...obvious value to ask before do...thank you...
Nickp is offline
post #10 of 42 (permalink) Old 12-06-2012, 07:59 AM Thread Starter
Nickp's Avatar
First Name: Nick
Looks like my "don't know" list is longer than I thought...thank you...
Nickp is offline
Making a Zero Clearance Fence for Drawer Lock Bit gerrym526 Table-mounted Routing 7 03-16-2010 09:08 AM
Router bits speedo Router Bits - Types and Usage 18 10-08-2009 03:17 PM
