Cross dowell help - Router Forums
post #1 of 7 (permalink) Old 06-09-2013, 10:04 AM Thread Starter
First Name: bob
Default Cross dowell help
Hello folks. I am currently making a dining room table and would like to cross dowel the leg/stretcher assembly to the mounting sill for the slides. I have never cross doweled before. The legs are 3 1/2 square hickory and I want to cross dowel a 2 x5 inch sill across the top of the leg assembly to screw the slides onto.
Any suggestions as how best to line up the three holes?
drbbob is offline
post #2 of 7 (permalink) Old 06-09-2013, 11:27 AM
Honored Member
First Name: pat
Yes I think so.
Quillman is offline
post #3 of 7 (permalink) Old 06-09-2013, 02:00 PM
Forum Moderator
Semipro's Avatar
First Name: John_*
Bob
Do not if this would help but woodpecker sales cross dowel jig
[url=http://www.woodpeck.com/crossdoweljig.html]Cross Dowel Drill Jig[/url
Semipro is offline
post #4 of 7 (permalink) Old 06-10-2013, 01:20 AM Thread Starter
First Name: bob
Thanks for the help guys, but I don't think either one of these will work for my application. The woodpecker jig won't index in far enough to center the hole in the end of the leg.
The other jig is too pricey for my budget and you're still left with trying to drill the holes perpendicular to each other.
drbbob is offline
post #5 of 7 (permalink) Old 06-10-2013, 06:32 AM
neville9999's Avatar
First Name: Neville
Send a message via Yahoo to neville9999
Originally Posted by Quillman View Post
Pat thanks for the link, I had not seen that site before, he makes a neat circle jig. NGM
neville9999 is online now
post #6 of 7 (permalink) Old 06-10-2013, 07:25 AM
Neville, Quillman is Pat Warner and that is his site. If you like what you saw there you should check out his books.
post #7 of 7 (permalink) Old 06-17-2013, 03:43 AM
First Name: Neville
Mike, thanks I will, I have had some set backs and I am only just now getting stronger so I will add that site to the ones that I will have a look at, I was always aware that as the USA is so large and the market is also very large then there must be a lot off cool stuff that just does not make it to Australia, for now I am working on my Router Lathe/Copier and it is looking very nice, it will work so as soon as I can then I will post a photo of my 35mm P&N Skew with a 13 sided handle attached. NGM
Jerry's latest observation on accurate cross cuts Jerry Bowen Tools and Woodworking 32 10-15-2012 10:34 PM
Making a cross or a crucifix Grumpy Old Tom Project Plans and How To 3 07-31-2012 01:21 PM
Cross Thread Timco New Member Introductions 14 07-06-2012 04:21 AM
Cross Slide Vise for Benchtop Mortiser Michael H Tools and Woodworking 29 10-21-2009 09:27 AM
Church cross DPLRBruno Show N' Tell 8 03-20-2009 08:26 AM
