Modifying the Kreg Pocket Hole Jig - Router Forums
 11Likes
post #1 of 26 (permalink) Old 11-14-2013, 11:37 AM Thread Starter
Forum Moderator
MT Stringer's Avatar
Default Modifying the Kreg Pocket Hole Jig
Some of you have probably seen my Pocket Hole jig set up (pics shown below). It works great. I have drilled hundreds of pocket holes with it. But, therein lies a problem. When I am drilling holes in panels such as plywood cabinet members, I have difficulty reaching around or over the panel to operate the clamp. In fact, on more than one occasion, I have scraped my arm. That is not good for a guy with thin blood.
So, in the words of Tim, The Tool Man Taylor “So I rewired it!” :-)
I know what you are thinking – A new model has just come out with the handle on the users side of the jig. I didn’t want to buy a new jig when I have a good one already. It just needs to be Mikeyized! :-)
My plan is to mount an air cylinder on my current setup that is actuated pneumatically by a foot operated switch.
Since the next step up from the manual jig is the Kreg Foreman ($849), I should be able to accomplish my modification for under $100 or maybe a little more.
My next round of building cabinets for our kitchen should be a lot smoother and make me a lot more productive.
Something I had on hand is a piece of 1/4 inch aluminum plate 3 inches wide x 12 inches long. I decided to mount the cylinder on it. But first, I made an exact duplicate out of 1/4 inch mdf so I could figure out how and where to mount everything.
After removing the clamp mechanism that came with the jig, I commenced to measure and drill mounting holes in the mdf. Then I transferred the holes to the aluminum plate by simply drilling through the holes in the mdf.
I don’t have a picture, but I used the original nuts that were used to secure the clamp. I used JB Weld epoxy to permanently mount them in the sockets underneath the jig.
I countersunk the heads of the mounting screws for the front and back cylinder mounts.
With everything fitted and working, I decided it was time for a new sled to mount the jig on. So, I recycled a piece of 3/4 inch plywood I have had since the mid 80’s. It was originally a box that pump parts had been shipped in and I salvaged it from the dumpster at work. Now it has a new life. Unfortunately, it wasn’t big enough so I added rear deck by gluing on a piece of maple. Once everything was dry, I added an edge all around and ran it through the drum sander until I had two smooth sides. I also needed new extensions for each side of the jig so longer material can be supported so I glued up two pieces of 1/2 inch Baltic birch. That turned out nice.
Final assembly and overview
Time to get this project wrapped up.
I covered the plywood deck with white Formica as well as the material supports and the rear support for the cylinder. After trimming the laminate flush with the plywood, I used a chamfer bit to bevel the edges slightly.
The original four 10-24×1 inch machine screws secure the front of the plate. Two 1/4 -20×1 inch round knobs attach the rear of the plate to the sled. If necessary, I can remove the cylinder as a unit.
And now for the good part. If something breaks, I can simply remove the four screws and the two 1/4 inch round knobs, remove the air cylinder unit and replace it with the original clamp!!! :-)
But wait, there is more!
If I need to drill pocket holes in 2x lumber, I will have to reposition the air cylinder. To do that, I simply remove the four 10-24 machine screws which will free up the sled. Then I will need to remove the four wood screws on the bottom side of the sled which keep the rear cylinder support in place. After determining the position for the cylinder, put the screws back in the aluminum plate, and drill new screw holes on the underside of the sled so the rear support will stay put. No need to remove the two 1/4 – 20 round knobs.
I drilled a few holes and the jig is working great. I had the air compressor set at 80 psi. I think I can easily reduce it to 60 psi.
The only thing left is to get a filter for the air line. The specs call for a 40 micron filter. HF has one that should work just fine.
I hope you enjoyed reading about this build as much as I did building it.
Name:	F13-Jig overview1.jpg
Name:	2012-03-21 19.25.28-1.jpg
Name:	2013-11-11 13.57.23.jpg
Name:	2013-11-10 17.09.26.jpg
Name:	2013-11-11 14.37.39.jpg
Name:	2013-11-11 14.38.30.jpg
Name:	2013-11-11 17.38.55.jpg
Name:	2013-11-11 18.13.33.jpg
Name:	2013-11-11 18.12.59.jpg
Name:	2013-11-12 22.10.42.jpg
Name:	2013-11-13 12.57.28.jpg
kp91, Roggerwood and jj777746 like this.
MT Stringer is online now
post #2 of 26 (permalink) Old 11-14-2013, 12:00 PM
TwoSkies57's Avatar
Holy crap Batman.. a pneumatic, foot actuated clamp. Now that has to be one of the coolest mods I've seen done to a Kreg rig. No doubt that this will be a very popular upgrade for alot of guys.
Outstanding!!!
bill
jj777746 likes this.
Skipper the Penguin
TwoSkies57 is offline
post #3 of 26 (permalink) Old 11-14-2013, 12:15 PM
Nice job Mike. One question: that looks like a double acting cylinder. Is it, and if it is, why do you go with that instead of a single acting with spring return?
post #4 of 26 (permalink) Old 11-14-2013, 12:17 PM
Cochese's Avatar
First Name: C
If you aren't a member of the Kreg forums, you'll have to post it there.
That is insane, and that's a high compliment from me. I'm just glad I picked up a K3MS on sale before it went the way of the dodo.
The 144 Workshop - Ambitious but rubbish woodworking
Cochese is offline
post #5 of 26 (permalink) Old 11-14-2013, 01:39 PM Thread Starter
Forum Moderator
Thanks for the kudos.
@Chuck - yes it is double acting. When I started this project, I had little to go on, so that is what I bought. And the foot switch works well with it. I think a single acting cylinder would be OK if it has a spring to retract the piston.
If I was to do it again, I would prolly go with a smaller cylinder...maybe 1 1/2 inch bore instead of the 2 incher. The stroke is only one inch but that seems to be OK.
Yeah, I am a member on the Kreg Jig Owners forum. I don't know how well it would be received to post a jig that has been modified. I will browse around and see if others have posted anything similar. Personally, I haven't found anything on the internet like this. I have seem some shop made mods using wood but not pneumatically operated.
post #6 of 26 (permalink) Old 11-14-2013, 04:39 PM
Country: Brazil
First Name: Cláudio
Very good Mike.
Job of Engineer
Kreg will have to upgrade your project.
Botelho007 is offline
post #7 of 26 (permalink) Old 11-14-2013, 04:46 PM
Smile
Originally Posted by Botelho007 View Post
Very good Mike.
Job of Engineer
+1.
Kreg will have it on the market under 12 months........
Sydney, Australia
jw2170 is offline
post #8 of 26 (permalink) Old 11-14-2013, 05:13 PM
Nice job Mike
Kreg will not have it on the market place would make it to high in price but if I recall they have one that's on the front side of the fixture.it may not be Kreg but some has one out in the market place for the short arm guys,,
Kreg - Home
Kreg K5 Jig Pocket-Hole Jig System
Name:	K% pocket hole.jpg
post #9 of 26 (permalink) Old 11-14-2013, 05:28 PM
roofner's Avatar
First Name: Gary
Kreg new k5 is in the front again like the k3 but looks like cheap plastic clamping unit but an auto clamping mechanism. Not at Lowes yet so can't totally comment yet.
roofner is offline
post #10 of 26 (permalink) Old 11-14-2013, 05:51 PM
TwoSkies57's Avatar
I checked the new K5 out a couple weeks ago and to be honest, wasn't too terribly impressed with the "new" unit. No doubt it will maintain the standards we've come to expect but IMHO the new stuff has added to the jig just for the sake of putting a new version out on the market. I can't speak to the clamping mechanism since I didn't get to use the thing. I can't see it lasting long in a production type atmosphere. The little handy dandy tool holders are nice, just would have like to seem em a little sturdier. The ratcheting clamp may be the nicest new feature of em all. If it works as advertised and holds up. The set up block looked handy...
Skipper the Penguin
How to Fill Pocket Hole kawisser Tools and Woodworking 9 10-31-2011 03:01 PM
First Box Joints w/a Hart Design Jig Wild Rag Jigs and Fixtures 2 03-23-2009 08:54 AM
Pocket Jig joe51 Jigs and Fixtures 5 12-16-2008 10:59 PM
Pocket hole jig hawker44 Jigs and Fixtures 6 10-23-2005 10:19 AM
