Ok, I tried Bj's push block... - Router Forums
post #1 of 6 (permalink) Old 03-02-2008, 01:47 PM Thread Starter
Hamlin's Avatar
First Name: Ken
Default Ok, I tried Bj's push block...
I still have a few finishing touches to do to it. Need to attach some sandpaper to the face to help hold the material in place. There are a few... ummm.... mistakes made but, I think it will work, (I hope).
Bob, I'll toss in a few pics of the fence I was telling you about.
Name:	push block0001.jpg
Name:	push block0002.jpg
Name:	push block0003.jpg
Name:	router fence0001.jpg
Name:	router fence0002.jpg
Ken
"A VETERAN"
Hamlin is offline
post #2 of 6 (permalink) Old 03-02-2008, 02:33 PM
Hi Ken
You did a great job on the push block
I did play with the one picture ( more light so I could get a good look at it)
That should work great on the OP router table
I would suggest you cut the boards on the fence at 10 deg. on both, in the center, that way you can make some inserts that just to slip into place for as zero setup (chip breaker) and to block the black hole behind the bit...plus it will help the vac.system work better...
post #3 of 6 (permalink) Old 03-02-2008, 03:36 PM
challagan's Avatar
Nice job Ken, Bob will be proud
http://iowacarver.tripod.com/
challagan is offline
post #4 of 6 (permalink) Old 03-02-2008, 04:12 PM Thread Starter
Hamlin's Avatar
First Name: Ken
Thanks Bob,
Thanks Corey,
Not sure why that 1 photo turned out so dark. Thanks for brightening it up.
Fortunitely, the MDF mounted on that fence are beveled, haven't checked the angle on them though. I understand what you mean about closing up the hole to help with the vac. Thankfully, those pieces are adjustable and closes around the router bit. This kinda helps with the vac-setup.
Oh and Bob, did ya notice the knob? Thanks for the hints with those.
Ken
"A VETERAN"
Hamlin is offline
post #5 of 6 (permalink) Old 03-02-2008, 04:26 PM
Hi Ken
The bevel should be 10 deg. But you may not have the support behind to support that type of cut (because of the short stroke of the slots in the front of the fence ) if that's the case a T & G joint works well ,,I use both type on my router tables...
see bleow
"did ya notice the knob? " = yep sure did , easy stuff right and it will save you tons of money plus you can make them any size you want..
Thanks Bob,
Thanks Corey,
post #6 of 6 (permalink) Old 03-02-2008, 07:43 PM Thread Starter
Hamlin's Avatar
First Name: Ken
Ok, I have 2 fences that I salvaged from some drill press tables, lots of T-slots in them. I'd like to turn them into router fences, I think I can convert them over using your method there. I'll have to take a pic of one and send it to you in private to see what you think.
Ken
"A VETERAN"
Hamlin is offline
Deluxe Push Block bobj3 Jigs and Fixtures 111 12-25-2012 09:29 AM
Bj's push block (my version) Hamlin Hamlin's gallery 5 03-28-2008 04:09 PM
Modified Bj's push block Bob N Jigs and Fixtures 5 06-03-2007 10:13 PM
Push Block for the Oak-Park Box Jig bobj3 Bj's Gallery 0 11-30-2006 12:21 PM
Reducing thickness of butcher block through hole. tastley Tools and Woodworking 5 10-23-2005 01:06 PM
