Corner Radius Jig Maker - Router Forums
 26Likes
post #1 of 32 (permalink) Old 12-23-2015, 06:50 AM Thread Starter
vindaloo's Avatar
First Name: Angie
Default Corner Radius Jig Maker
I began making some rail and stile cabinet panels. I rebated for the panel to fit within the rails and stiles and cut the 'square' panel. In the past I've chiseled the corners square to match but looking at the corners I remembered reading about Kriss' ( @FastEasySmartTOOL ) corner radius jig making jig.... whew, mouthful there. So I decided to build one.
Unfortunately my RT has no useful holes within it, nor is it conducive to clamping the parts to, so a base was required. Then the problem of making the adjustable parts, well, adjustable. Taken care of using a couple of coach bolts with my shop made star knobs.
As you can see, all went well.
Then I needed somewhere to store the things, so a small panel with cleat and dowel, and up on the wall they went.
Used the 3/4" one today and the panel slotted straight into the rail/stile frame. Wow, thanks Kriss, this is gonna save me lots of time.
Name:	2015-12-23 h12m12 0397 (L840).jpg
Name:	2015-12-23 h12m11 0395 (L840).jpg
Name:	2015-12-23 h12m11 0394 (L840).jpg
Name:	2015-12-23 h12m12 0398 (L840).jpg
Name:	2015-12-23 h12m13 0399 (L840).jpg
Name:	2015-12-23 h12m13 0400 (L840).jpg
When everything around you is going to pot, get out in the workshop.
vindaloo is offline
post #2 of 32 (permalink) Old 12-23-2015, 07:03 AM
well done ...
post #3 of 32 (permalink) Old 12-23-2015, 08:07 AM
Nickp's Avatar
First Name: Nick
Nice...cool storage too...
Nick
Nickp is offline
post #4 of 32 (permalink) Old 12-23-2015, 12:13 PM
bryansong's Avatar
First Name: bryan
Well I wish I understood this but I'm sorry I don't. They do look well made though.
Maybe when I get a router table setup it will make more sense to me.
Bryan
bryansong is offline
post #5 of 32 (permalink) Old 12-23-2015, 01:34 PM
Bryan
These are for making rounded corners on flat materials, like the corners of a table for example. They are really templates that are attached over (or under) the corner of the workpiece. You can then use the template to draw a line so you can cut most of the corner away (band or jig saw cut just outside the pencil line.) You then use a "trim" router bit with a bearing, resting the bearing against the template's curve. This bit cuts to the exact shape of the jig so you get a good edge and a perfect rounded corner. He made a number of them.
The aluminum L bar is deeper than the template is thick so they hold the template in place on the workpiece, but are set back far enough to be out of the way of the router trim bit.
He made many sizes so he can use them later. It is always easier to make all of the same type of jig at the same time.
Cutting rounded corners freehand is basically impossible. No one is steady enough to do that. Jigs like this take a lot of careful cutting, then sanding to the final shape.
You can buy plastic circle drawing templates with marks every 90 degrees to line up on the corners of the jig material. Draw the line, then cut and sand the jig, attach the aluminum L brackets, drill a large hole so they can be stored on the pole device in the final picture.
Very smart way to do this. You could even use double sided tape to hold the jig in place a little more firmly. But the pressure of the trim router bit would probably hold it in place quite well without the tape.
The more you get into woodworking, the more you will like jigs. They make good results easier and make matching parts a snap.
Web Shepherd and jj777746 like this.
post #6 of 32 (permalink) Old 12-23-2015, 01:39 PM
Bryan
I thought the same thing when I first read it, maybe this video will help
tomp913 is offline
post #7 of 32 (permalink) Old 12-23-2015, 01:44 PM
Contributor of the Month
PhilBa's Avatar
First Name: phil
nice job on the jigs. I particularly like the use of the aluminum Ls, makes for quick and precise alignment. Might borrow that. One tweak for future makers of these, you can probably get 2 radius's (radii, I believe) per jig.
Double sided tape should be sufficient. I use it all the time to hold templates in place. Works great but you have to make sure both pieces are clean and flat.
Visit my shop website.
PhilBa is online now
post #8 of 32 (permalink) Old 12-23-2015, 02:08 PM
Oh boy, more jigs!
post #9 of 32 (permalink) Old 12-23-2015, 02:25 PM
kp91's Avatar
First Name: Doug
Now I feel like a bad father... my kids don't have anywhere near as nice of a shop to work in! Maybe I should upgrade a few tools, you know, for them....
Nice project, and thanks for introducing me to those videos!
thomas1389 and Semipro like this.
1 John 1:9
Fredericksburg, VA
kp91 is online now
post #10 of 32 (permalink) Old 12-23-2015, 04:11 PM
get a retired cargo ship/behemoth and turn that into a shop..
I'm sure the neighbors won't mind the view being blocked...
kp91 likes this.
Modifying the Kreg Pocket Hole Jig MT Stringer Jigs and Fixtures 25 10-02-2014 11:10 AM
My First Jig Coleve Show N' Tell 14 03-10-2013 09:12 PM
Dovetail Jig Tip jlord Jigs and Fixtures 4 11-04-2011 11:20 AM
Need Jig for Dovetailing ½” stock + Rockler woes + Katie? JavaGeek Jigs and Fixtures 16 02-17-2011 02:46 PM
Corner Radius bobj3 Tools and Woodworking 25 09-29-2007 06:51 PM
