Vertical Routing Sled - Router Forums
 21Likes
post #1 of 36 (permalink) Old 01-01-2016, 05:09 PM Thread Starter
Contributor of the Month
Default Vertical Routing Sled
I just received an email from Infinity advertising a vertical routing
sled. Any plans available for a homemade one? I put together a vertical routing table but haven't used it yet
JIMMIEM is offline
post #2 of 36 (permalink) Old 01-01-2016, 06:09 PM
are you referring to a horizontal router...
Woodhaven 6002 Horizontal Router Table & 3.5" Angle Ease : Horizontal Router Table
KennK likes this.
post #3 of 36 (permalink) Old 01-01-2016, 06:39 PM
Semipro's Avatar
First Name: John_*
I believe he is refering to this
http://www.infinitytools.com/Vertica...m_medium=email
Semipro is offline
post #4 of 36 (permalink) Old 01-01-2016, 07:07 PM
now we're talking...
that looks easy enough to reverse engineer...
post #5 of 36 (permalink) Old 01-02-2016, 12:18 AM
When's the last time you needed to run a board across a router bit at an angle for a tapered profile? This reminds me of Titebond's claim of waterproofness. It looks to me like they're trying to sell something of no consequence for $139.
Herb Stoops and Moz like this.
post #6 of 36 (permalink) Old 01-02-2016, 12:26 AM
toys...
gotta have toys...
Roy Drake likes this.
post #7 of 36 (permalink) Old 01-02-2016, 07:19 AM Thread Starter
Yes, this is what I'm referring to.
JIMMIEM is offline
post #8 of 36 (permalink) Old 01-02-2016, 08:48 AM
Honored Member
First Name: pat
I think it has merit.
I made the analog, that is, a stationary holder platform that can hold
the work on end. (To a degree, the production model from Infinity,
has ~ the same flexibility.) It's in an old (out of print) book of mine:
"Fast Accurate Router Jigs"
But mine works with edge guides so the resultant end cuts are independent of the work's condition or section.
Sample cuts.
Herb Stoops and cocobolo1 like this.
Quillman is offline
post #9 of 36 (permalink) Old 01-02-2016, 10:18 AM
Guest
First Name: Regis
Jim,
I made one from odds and ends around the shop. It is designed to hold the vertical member being cut for a lock miter joint. The cutter tends to push the member up and away from the fence and it is pretty much impossible to hand hold the board and guide it through the cut. I made mine to use the existing 8" high fence and the 3/4" groove for holding Bench Dog feather boards. It's adjustable for boards 21/4 to 5" wide but narrower boards can be held with a spacer. The bar across the bottom is a handle that allows applying pressure against the fence and the cam disc helps resist the outward force that the cutter applies to the work piece. The push bar is relieved to accept boards up to 1" thick. The guide rail in the groove is there to resist the upward force of the cutter. It's probably overkill but the top backer piece rides on the top and back of the fence to resist the outward force of the cutter. Both the groove and top edge of the fence as well as their counter parts are waxed to help move the whole contraption carrying the work piece through the cutter. For harder wood I clamp the work piece to the right side member to resist the upward force. It didn't cost $139.00 + shipping!
Regis
48394 is offline
post #10 of 36 (permalink) Old 01-02-2016, 03:49 PM
I more than like this...
Use of template Guides cutter79 Guide Bushings and Templates 6 08-21-2013 03:18 AM
Routing two posts vertical - Help please britinfrance Portable Routing 3 04-09-2012 12:28 PM
routing vertical words kschatten General Routing 4 06-05-2010 06:13 AM
VIDEO - Shop built Mitering and Crosscut Sled johnwnixon Tools and Woodworking 5 09-06-2009 10:14 AM
vertical mounting routing tables ryanb Table-mounted Routing 2 01-01-2009 06:40 PM
