Routing 6061 Aluminum HELP! - Router Forums
 4Likes
post #1 of 16 (permalink) Old 01-06-2016, 11:19 AM Thread Starter
Jack Wilson's Avatar
First Name: Jack
Question Routing 6061 Aluminum HELP!
Hey guys and gals,
I want to make a template, or jig, out of aluminum, essentialy a stair routing template. I have made them out of wood before, many times, but I want to try something more durable. I'd like to try my hand at routing an aluminum template out of 1/2" 6061 stock and am looking for ANY advice I can get....
Thanks!
Jack
He is no fool who gives what he cannot keep to gain what he cannot lose
If you cannot stand behind our troops, (and I understand, no judgement here), then please stand in front of them, remember, they're willing to stand in front of you!
Jack Wilson is offline
post #2 of 16 (permalink) Old 01-06-2016, 11:27 AM
First off, it will make a mess.LOL I have never router a piece that thick, you will probably have to do it in small increments of depth.
You will probably be using a template and a bushing and hand held router. years ago when I worked in a machine shop, they did it all the time making aircraft parts and had to use a liquid coolant on the bit and a spiral bit, can't remember if it is up or down spiral.
Someone will be along with all the information soon.
Also the type/grade of material matters a lot,some machines better than others.
Herb Stoops is offline
post #3 of 16 (permalink) Old 01-06-2016, 11:50 AM
sunnybob's Avatar
Country: Cyprus
First Name: Bob
my best advice is buy one already made.
Or go to a machine shop, because youre bound to screw up once, and unless you have free access to the ali, your money and time spent will make it a very expensive jig.
Semipro and Herb Stoops like this.
sunnybob is offline
post #4 of 16 (permalink) Old 01-06-2016, 01:07 PM
RainMan 2.0's Avatar
I've routed aluminum but fairly thin . You need to cut out the majority of the material as close as you can to the size needed , then have a router bit guided by an mdf template to take off the rest . Have someone spraying wd40 as the bits routing out the aluminum
Ok ,I never insulate
RainMan 2.0 is offline
post #5 of 16 (permalink) Old 01-06-2016, 01:52 PM Thread Starter
First Name: Jack
No free access here, but nothing ventured, nothing gained. Yes, I will be using a hand held router, a Porter Cable 7518, single speed so it might be the 19, I can't remember. Part of it is to save money, buying one is crazy expensive, and part of it is simply learning to do it myself, and actually doing it myself. Make one, figure out how it goes, that opens the door for next time. I don't want to be afraid to try, hell, I don't want to be afraid of anything. Fear is my enemy. Wisdom is my friend.
Roy Drake likes this.
Jack
post #6 of 16 (permalink) Old 01-06-2016, 02:32 PM
Nickp's Avatar
First Name: Nick
...for cutting slots in closed stringer...? or to set step and riser...?
Nick
Nickp is offline
post #7 of 16 (permalink) Old 01-06-2016, 02:47 PM
That is a good question, and difference in making the template. I just ass-ssumed it was closed stringer. Another question is how long will this template be,for how many treads and risers? Will it be adjustable for different runs and rise? Hmmmm so many variables........
Maybe do a mock up in Baltic Birch plywood?
post #8 of 16 (permalink) Old 01-06-2016, 03:11 PM Thread Starter
First Name: Jack
It's for housed stringers, so it will route out the run with nosing, and the riser. It will also include the space needed for stair shims. No baltic birch necessary, I have made these before but always out of plywood. There is no rise/run, or pitch, it's simply one tread and riser. I clamp it down, route and then move it to the next step and repeat. The rise/run is set by the angle that the template is clamped to. The real question remains, practical advice on routing aluminum.
Jack
post #9 of 16 (permalink) Old 01-06-2016, 03:25 PM
Nickp's Avatar
First Name: Nick
Yup...got it...mine is plywood also...aluminum sounds like a great idea but thinking you might need liquid coolant and slower speed...
Jack Wilson likes this.
Nick
Nickp is offline
post #10 of 16 (permalink) Old 01-06-2016, 06:24 PM
The second best car audio installer in North America (The FishMan) routes aluminum all the time . Exactly as I described it
CNC Routing Aluminum Face Plates - Need Help Mahonroy CNC Routing 9 06-13-2015 07:57 PM
Need help Routing half inch aluminum diego06310 CNC Routing 8 11-10-2014 12:05 PM
Use of template Guides cutter79 Guide Bushings and Templates 6 08-21-2013 03:18 AM
Looking for help routing aluminum 6061 t6 Danbya General Routing 23 06-12-2011 04:14 AM
Routing Aluminum table saw top?? frostr2001 General Routing 22 10-02-2009 03:09 AM
