Thin strip ripping jig - Router Forums
 33Likes
post #1 of 94 (permalink) Old 01-13-2016, 02:14 AM Thread Starter
Default Thin strip ripping jig
I've been meaning to make a thin strip ripping jig for a while now, since someone posted one they bought. I've kept all my fingers doing it the old fashioned way all these years but why push my luck when better technology is available?
This particular build is for a Unisaw which has a T slot for the miter slots. A 5/16" washer fits the T slot very well so I countersunk them for 5/16" flat head machine screws. I had a piece of birch hardwood that was about 1" thick that was a bit narrow so I decided to use 2 pieces glued together. This actually made building it easier as I cut the slots for the bolts on the table saw instead of doing it with a plunge router and once the slots were cut I glued the two halves together.
I decided it could use a little fine adjustability so I drilled and tapped one face for a 3/8 x 16 thread/inch carriage bolt and the opposite face I tapped a 6mm x 1mm thread/inch metric carriage bolt in case I'm working in metric (the metric one is what I had in my spare parts). Hardwood threads just fine with metal cutting taps but I used very slightly smaller drills than my charts called for. The carriage bolts I thought were a good choice as the domed heads are low drag and the square shoulders behind the heads make it easy to count turns for the fine adjusting.
There are many variations on this idea. This is only one of the possibilities.
Murtu01 and alan.mullock.3 like this.
post #2 of 94 (permalink) Old 01-13-2016, 02:27 AM Thread Starter
The other picture I tried uploading.
Nickp and Murtu01 like this.
post #3 of 94 (permalink) Old 01-13-2016, 06:31 AM
chessnut2's Avatar
Looks interesting, Charles. Could you post a little more info on how it works? Thanks. Jim
Moz likes this.
chessnut2 is offline
post #4 of 94 (permalink) Old 01-13-2016, 07:27 AM
DonkeyHody's Avatar
First Name: Andy
I've never used a thin-rip jig. I've always just set the fence close to the blade and used a sacrificial fence if it was really close; but I'm always up for a better ways to do things. I have a magnetic featherboard like this one. Could I just lock it down with the nose toward the workpiece and use it in place of the jig? Or am I missing something?
DonkeyHody is offline
post #5 of 94 (permalink) Old 01-13-2016, 07:33 AM
kywoodchopper's Avatar
First Name: malcolm
Hi Charles, you are right to keep the fingers away from the blade. I cut a lot of 1/8" thick splines. Instead of sawing them that narrow, I plane the boards, maybe 6" wide, to 1/8" thick then use the table saw to cut them to the width that I need. It is much safer and ensures the correct thickness. My planer has spiral cutter head and has a 3/4" thick support board in the base of the planer. I have no problems planing wood that thin. Malcolm / Kentucky USA
kywoodchopper is offline
post #6 of 94 (permalink) Old 01-13-2016, 08:03 AM
some times rips need to be done for grain orientation...
ie.. shape layups...
post #7 of 94 (permalink) Old 01-13-2016, 08:35 AM
hawkeye10's Avatar
First Name: Don
I have been wondering for a long time why anyone would need a thin rip jig. I am left handed so my fence is one the right side of the blade. If I want to cut thin strips I put the board on the right side of the blade and adjust the fence for the thickness I want the thin strip to be. The thin strip just falls to the right of the blade. I know a jig would be better or y'all wouldn't be talking about it. So can you explain why a jig is better?
Don in Murfreesboro,Tn.
hawkeye10 is offline
post #8 of 94 (permalink) Old 01-13-2016, 08:43 AM
vchiarelli's Avatar
First Name: Vince
Don
A jig is like a stop block - by keeping the jig in place and moving the fence, the size of the thin strips will always be the same but will prevent the strip from getting caught between the blade and the fence as the strip is cut to the opposite side of the blade.
I don't use a jig for thin strips - I use my GRR RPR with a 1/4" leg and the strip cut between the blade and the fence. The GRRpr allows you to push both pieces through to the outfeed side and maintaining control of the strip until it clears the blade.
You can get an accessory leg for the GRRPR that allows you to rip 1/8" strips.
mjadams61 likes this.
vchiarelli is offline
post #9 of 94 (permalink) Old 01-13-2016, 09:06 AM
Country: Mexico
First Name: Joseph Anthony
Question
Originally Posted by vchiarelli View Post
Don
Vince, could you post some pics about this procedure?
RÖENTGEEP is offline
post #10 of 94 (permalink) Old 01-13-2016, 09:57 AM
plan ''A'' (shorts)...
sled...
stop block set to thickness desired...
proceed w/ rips/crosscut...
plan ''B'' (long)...
set fence to thickness desired...
rip 60% of the stock's length...
lift stock off of blade...
flip stock end for end...
complete rip...
set drop aside...
repeat cycle...
jw2170 likes this.
Kelly's New Router Jig Dejure Jigs and Fixtures 1 01-19-2014 12:09 AM
My First Jig Coleve Show N' Tell 14 03-10-2013 08:12 PM
Greater than japa62 Jigs and Fixtures 12 01-16-2013 12:03 AM
TS Thin strip jig Router is still my name Jigs and Fixtures 8 01-05-2011 10:58 PM
question Henry Fernandez Starting Off 14 02-11-2008 05:46 PM
