Jig for an aircraft wing - Router Forums
 1Likes
post #1 of 24 (permalink) Old 01-17-2016, 01:16 AM Thread Starter
CEOoftheSOFA's Avatar
First Name: Abraham
Default Jig for an aircraft wing
Hi everyone... I need to create a jig to route off the area encircled in red. It is imperative that i do not touch the green area (wing rib) and the yellow area (wing spar). This is all new to me but I think my shop is equipped well enough to do the job.
CEOoftheSOFA is offline
post #2 of 24 (permalink) Old 01-17-2016, 03:24 AM Thread Starter
First Name: Abraham
Here is one that was suggested to me.
post #3 of 24 (permalink) Old 01-17-2016, 04:15 AM
furboo's Avatar
First Name: Rob
Hi Abraham, does the bottom of the cut on the spar have to follow exactly the shape of the rib (such as if you're putting on a skin of a specific thickness)? Or can it be flat?
Assuming flat is OK, the jig you show looks fine, except that I'd put in adjustable guides (or stops) on the ends so that you don't cut into the ribs. You don't really need accurate spanwise guides (the dark wood in your jig), because you're removing the full width of the spar.
You may have mentioned this in another thread, but what airplane are you building?
furboo is offline
post #4 of 24 (permalink) Old 01-17-2016, 07:04 AM
neville9999's Avatar
First Name: Neville
Send a message via Yahoo to neville9999
Its not clear to me how much of the red area has to be routered out but this suggested jig is about what I would make, you need flat areas on each side of the cut for the router to rest on and the gap should be made to suit what ever pilot guide will be used, this type of jig would work you just have to make the sides of the gap to suit the cut, the depth of the cut gets set by the depth of the cutter. N
neville9999 is offline
post #5 of 24 (permalink) Old 01-17-2016, 08:28 AM
The jig looks OK, but only if the top of the spar is to be flat. If it is to be at an angle to match the shape of the green cross piece then you might need to set up the jig so it is at the angle you want. I would also suggest using a Japanese pull saw to cut the ends of the red area so the router doesn't have to travel all the way to the green. Even if the router eliminates most of the waste, you will still need to trim the small trianvles it will leave at the end. Perhaps another option would be to tape then clamp a half inch thick sacrificial piece on each side of the spar, then make the guide fit that. Route the spar and the sacrificial piece both, then your bit will make a cleaner cut and won't tear out and you won't have the remains. I assume you'll use a relatively short mortising bit with the guide bearing on the shaft end of the bit. I'd be very careful about the depth of cut and would sneak up on it gradually. Those FAA inspectors can be nit picky.
post #6 of 24 (permalink) Old 01-17-2016, 09:49 AM
Garyk's Avatar
First Name: Gary
Careful, aircraft wood is $$$$$$$. The jig looks ok but I would use a chisel and wood rasp on the ends of the cut to insure I did not touch the metal ribs. What aircraft are you working on. I had to replace the wing spar on an Aeronca Champ rebuild. Started out with the metal framework and replaced everything else with new material. Fun project.
Garyk is offline
post #7 of 24 (permalink) Old 01-17-2016, 10:03 AM
thanks for the way better pic...
I believe Phil hit it w/ this one...
post #8 of 24 (permalink) Old 01-17-2016, 11:01 AM Thread Starter
First Name: Abraham
Originally Posted by furboo View Post
Hi Abraham, does the bottom of the cut on the spar have to follow exactly the shape of the rib (such as if you're putting on a skin of a specific thickness)? I don't really understand the question because the rib is where the routing stops. The cut will follow the spar and stop at the rib(s) Or can it be flat?
Assuming flat is OK, the jig you show looks fine, except that I'd put in adjustable guides (or stops) on the ends so that you don't cut into the ribs. You don't really need accurate spanwise guides (the dark wood in your jig), because you're removing the full width of the spar. Any suggestion how I can add these guides
Building a Steen Skybolt
post #9 of 24 (permalink) Old 01-17-2016, 11:05 AM Thread Starter
First Name: Abraham
Forgot the money aspect do you know how much work would be involved if I damaged the spar
post #10 of 24 (permalink) Old 01-17-2016, 11:10 AM
how much of your airplane was a ''kit''...
Mini Fence by Krymi Corp CharleyL Tools and Woodworking 37 07-23-2018 07:58 PM
Porter Cable 55160 Omnijig Review Echonav Tool Reviews 19 06-21-2015 03:59 AM
New circle jig Ghidrah Jigs and Fixtures 10 03-04-2015 06:22 AM
My First Jig Coleve Show N' Tell 14 03-10-2013 09:12 PM
Jig Fabrication Tony1012 Jigs and Fixtures 2 03-31-2011 09:21 PM
