Stop Chamfering 1.50" Spindles - Router Forums
post #1 of 6 (permalink) Old 01-17-2016, 12:55 PM Thread Starter
First Name: Dale
Default Stop Chamfering 1.50" Spindles
I'm restoring our 1850 Victorian home. The side porch is currently being restored and I need to manufacture about 200 1.75" square spindles that have Each corner Stop chamfered with Lambs tongue. All the posts are being made from 2" poplar.
I have a shapers and routers, so I'm looking for some suggestions of how you would produce these items using those tools. Has one developed a jig, for their use, to manufacture a similar item?
I appreciate you thoughts,
needshave is offline
post #2 of 6 (permalink) Old 01-17-2016, 01:18 PM
always hand made them...
Online Extras - Woodsmith Magazine
why the poplar for spindles....
Stick486 is offline
post #3 of 6 (permalink) Old 01-17-2016, 01:25 PM
This is what Lee Valley suggests but it seems very labor intensive Lee Valley Tools - Woodworking Newsletter
The bottom curve of the tongue I think I would try to do with a sanding drum, preferably on a spindle sander. That would be a one step process. The drum would cut it and finish it or use a coarse drum and the switch to a finish drum. The curve from the long chamfer to the ess in the tongue could possibly be done with an ovolo bit going cross ways. <strong>Industrial router bits</strong>-Ovolo router bits-CMT tools
post #4 of 6 (permalink) Old 01-17-2016, 02:14 PM
machine the chamfer..
scroll saw the the tongue w/ the spindle in a V carriage...
Stick486 is offline
post #5 of 6 (permalink) Old 01-17-2016, 06:02 PM Thread Starter
First Name: Dale
This same property that I was referencing, also has a carriage house on it. The carriage house, as you might expect, was used to house carriages in a previous life and has an enclosed attic that contained almost 2000 bd ft of 8/4 sticked poplar. Most of the current spindles that I'm restoring are also made of poplar. So, I just decided to use it.
post #6 of 6 (permalink) Old 01-18-2016, 08:32 AM
Garyk's Avatar
First Name: Gary
If you have a custom "Period" furniture maker close check with them for in-house made bits. One in Columbia SC has a machine like a key maker that they use to make bits with special profiles. With the right profile & a shop made angle jig that may work for production. Might cost too much but just a thought.
Garyk is offline
Maloof Inspired rocking chair build TwoSkies57 Project Plans and How To 281 06-16-2015 04:02 PM
Maloof Inspired rocking chair build TwoSkies57 TwoSkies57 Gallery 235 07-13-2014 05:29 PM
Kelly's New Router Jig Dejure Jigs and Fixtures 1 01-19-2014 12:09 AM
CC Sled Stop Block Slide Ghidrah Show N' Tell 2 04-21-2009 03:27 PM
home made ruler stop allthunbs Jigs and Fixtures 19 01-03-2009 03:44 PM
