Clamping Cauls for Box Joints - Router Forums
 19Likes
  • 11 Post By PhilBa
  • 2 Post By Arcola60
  • 1 Post By Stick486
  • 1 Post By Cherryville Chuck
  • 1 Post By furboo
  • 1 Post By chessnut2
  • 1 Post By old55
  • 1 Post By TwoSkies57
post #1 of 9 (permalink) Old 02-21-2016, 02:49 PM Thread Starter
PhilBa's Avatar
First Name: phil
Default Clamping Cauls for Box Joints
One of the challenges of making good box joints is clamping during glue-up. You can't clamp directly on the joints (because the fingers stand a bit proud) so we are forced to put clamping pressure next to the joint which introduces torque and pulls the sides in a bit. For 1/2" or thinner wood, this can cause small gaps in the box joint plus it distorts the sides of the box a bit and makes it hard to use an inside square to check the squareness of the box. See the attached picture for an example.
The solution to this problem is to use clamping cauls that allow you to place pressure directly on the fingers. There are commercial products that do this. In particular Rockler has them for 1/4", 3/8" and 1/2" finger sizes. The cauls are reasonably priced though you need a band clamp as well. While they do work, the fingers are open and, even with moderate clamping pressure, they press marks into the box fingers. See the attached picture. The wood is cherry and the mark was made just by squeezing with my arthritic fingers. Needless to say, this is not desirable.
So, the answer is to make clamping cauls yourself. It's not hard and if you have an Incra LS Positioner, it's really easy. I've put together a tutorial on how to do this with the Incra LS Positioner using Rob Lowrie's pyRouterJig software.
If you don't have an LS Positioner or similar, you can still make cauls. Basically, it's very similar to making box joints with fingers that are 1/8" deep. The caul fingers should be around 1/16" narrower than the box joint fingers. You cut them out of a 3 1/2" x 1" thick piece of hard wood. The length should be about 1 1/2" longer than the joint you are clamping. See the pictures to understand the process. It should be easy to modify your box joint jig to do this. But, it should be possible to make just using a dado blade and miter gauge - precision is not needed. You might want to look over the above tutorial to get a better idea of the process.
Note that the measurements in the attached pictures are for custom finger spacing - don't use those measurements for a standard spacing box joint.
The final picture has been posted before but it shows the results of getting direct, square and even clamping pressure via cauls on box joints.
Visit my shop website.
PhilBa is offline
post #2 of 9 (permalink) Old 02-21-2016, 03:10 PM
First Name: Ellery
Excellent work and great attention to detail Phil. The box joints look great also. Thank you very much for sharing it with us. I have been doing a few box joints for some shop boxes for tool storage. This will help with all of my box joints.
Ellery Becnel
Murtu01 and PhilBa like this.
Arcola60 is offline
post #3 of 9 (permalink) Old 02-21-2016, 03:30 PM Thread Starter
PhilBa's Avatar
First Name: phil
Thanks man. Before using the cauls, I was really bothered by some of the gaps I was seeing. Bought the Rockler product and was really happy to see an improvement but then I had to sand to crap out of the sides to remove the clamp marks.
PhilBa is offline
post #4 of 9 (permalink) Old 02-21-2016, 04:34 PM
this is a well thought out and executed answer...
great joinery too...
PhilBa likes this.
post #5 of 9 (permalink) Old 02-21-2016, 05:20 PM
Nice solution.
PhilBa likes this.
post #6 of 9 (permalink) Old 02-21-2016, 08:12 PM
furboo's Avatar
First Name: Rob
Excellent Phil! Adding the caul templates to pyrouterjig was a great idea of yours, and it's nice to see it in action.
PhilBa likes this.
furboo is offline
post #7 of 9 (permalink) Old 02-22-2016, 10:35 AM
chessnut2's Avatar
Fantastic idea, Phil. Getting those joints clamped well is one of those things that we worry about in making those joints. Well designed, well drawn out and presented.
PhilBa likes this.
chessnut2 is offline
post #8 of 9 (permalink) Old 02-22-2016, 05:33 PM
old55's Avatar
First Name: Ross
Nice work Phil.
PhilBa likes this.
Ross,
old55 is offline
post #9 of 9 (permalink) Old 02-22-2016, 06:19 PM
TwoSkies57's Avatar
Phil's blogs are worth the read.....agree or disagree, points are well made and elevate the debate..
philsbunker
PhilBa likes this.
Skipper the Penguin
TwoSkies57 is offline
box joints? mah New Member Introductions 6 12-30-2012 10:48 PM
Incra Ultra How-To (Box Joints + Other Stuff) Nickbee Show N' Tell 17 06-22-2009 12:42 PM
