Jig for Drilling tops of closed T-Knobs - Router Forums
 11Likes
  • 6 Post By JohnnyB60
  • 1 Post By JIMMIEM
  • 1 Post By hawkeye10
  • 3 Post By JohnnyB60
post #1 of 7 (permalink) Old 03-10-2016, 12:38 AM Thread Starter
First Name: Johnny
Default Jig for Drilling tops of closed T-Knobs
So I got a pretty good deal on some 5/16” T-Knobs except that the threads did not go through the top. Well that doesn’t work for me and I don’t even know what to use these for without going all the way through.
It was a real pain to drill out the first one so I made a jig to hold them which made it so much easier.
JohnnyB60 is offline
post #2 of 7 (permalink) Old 03-10-2016, 07:24 AM
Contributor of the Month
Necessity is the Mother Of Invention!!!!!
JohnnyB60 likes this.
JIMMIEM is offline
post #3 of 7 (permalink) Old 03-10-2016, 07:27 AM
hawkeye10's Avatar
First Name: Don
Great idea!!!
Don in Murfreesboro,Tn.
hawkeye10 is offline
post #4 of 7 (permalink) Old 03-10-2016, 09:06 AM Thread Starter
First Name: Johnny
I nearly lost the first one trying to do it by hand. I tried drilling a pilot hole from the threaded side to locate the exact center on top but it wasn't so center when it came out. Then it nearly tore my hand off when I drilled down with the larger bit from the top and it hit the brass. The plastic was easy, but the knob turned in my hand flying across the room when the drill caught the brass thread.
I had 6 of them to do and it was just too dangerous so I decided that I needed something to hold it without breaking the plastic. I drilled all the way through with a 5/16 drill for a bolt to lock it in place. I then drilled a ¾” hole the depth of the knob and used my router table with my brand new lift to cut the slot for the handle.
Once I had the jig built it was just a matter of bolting the knob inside the jig which did two things. One was holding the knob in the jig holder and the other was a stop to protect the brass threads from being damaged if the drill bit were to pull it up.
After that it was a piece of cake because the drilling was a one-step drilling process and I got them all done with in the time it took to do one by hand.
OPG3, Stick486 and cocobolo1 like this.
post #5 of 7 (permalink) Old 03-10-2016, 10:13 AM
nicely done..
post #6 of 7 (permalink) Old 03-10-2016, 10:19 AM
Good thinking, Jonmmy.
Herb Stoops is offline
post #7 of 7 (permalink) Old 03-10-2016, 11:11 AM
Ghidrah's Avatar
First Name: Ronald
JohnnyB60,
I had a similar issue a while back, being the lazy WOF that I am I just grabbed them with a Jorgensen hand screw and clamped it to the drill press. Although I did the opposite of your tech by drilling from the bottom up with a brad point bit.
Ghidrah is offline
EZ Dovetail Jig bobj3 Jigs and Fixtures 7 04-02-2014 08:43 PM
Praises For JessEm Doweling Jig Jerry Bowen Tools and Woodworking 20 03-18-2014 06:41 PM
Peachtree 15 inch dovetail jig Noob Jigs and Fixtures 13 12-03-2013 08:37 PM
Jig Storage & Shop made Knobs Bob N Jigs and Fixtures 43 11-08-2011 02:29 PM
Dovetail Jig Tip jlord Jigs and Fixtures 4 11-04-2011 11:20 AM
