Made 6 Hold down clamps for legacy ornamental mill - Router Forums
 10Likes
  • 10 Post By davefrommd
post #1 of 6 (permalink) Old 04-09-2016, 11:00 AM Thread Starter
First Name: dave
Default Made 6 Hold down clamps for legacy ornamental mill
I made 6 hold down clamps from 1/4" thick 6061 T6 aluminum plate. i drilled and tapped 10-32 holes and am using 10-32-1/2 screws, the screws are to long as i needed 3/8 long screws, i cut the aluminum on my metal cutting bandsaw.
davefrommd is offline
post #2 of 6 (permalink) Old 04-09-2016, 11:10 AM
I like that, good pictures too. Looks like you used to be a jig builder at Boeing , thats the way they do it.
Herb Stoops is offline
post #3 of 6 (permalink) Old 04-09-2016, 11:33 AM Thread Starter
First Name: dave
i had those clamps laying around from a jig i used to make wooden feet for a music box, just getting ready to use my legacy ornamental mill once i figure out how to use it. it is similar to the sears router crafter.
post #4 of 6 (permalink) Old 04-09-2016, 12:57 PM
nicely done....
Stick486 is offline
post #5 of 6 (permalink) Old 04-10-2016, 08:20 AM
First Name: Buck
Dave, what is the blade you used in the bandsaw to cut the AL and how thick a piece of AL can you cut with it ?
BOjr is offline
post #6 of 6 (permalink) Old 04-10-2016, 12:23 PM Thread Starter
First Name: dave
i am using a harborfreight floor model metal cutting bandsaw with i believe a 10-14 tpi. the bandsaw it probably 10 years old and still cuts nicely, 1hp motor current model number is 93762. i am cutting 1/4" thick 6061 T6 aluminum plate. i did cut some 1/4" and 3/8" thick 6061 T6 aluminum plate on my dewalt 12" slider power miter saw with 60 tooth carbide tipped blade. oh how thick a piece i can cut with this bandsaw, 4"x6" thick, after the cut it trips a toggle switch and turns off. i have cut a 1 3/8" solid steel shaft before, it cut through it like butter.
Home made hand screw clamps Cherryville Chuck Jigs and Fixtures 8 11-28-2013 08:55 PM
Shop Made Vacuum hold down SteveMI CNC Routing 3 06-03-2011 08:15 PM
Shop Made Toggle Clamps for Gav Stefang Jigs and Fixtures 40 02-04-2011 05:38 AM
Home Made Cam Clamps... Joe Lyddon Tools and Woodworking 2 11-28-2006 10:07 PM
T Track Toggle Clamps Pop_pop1 Table-mounted Routing 4 07-29-2005 02:22 AM
