Harbor Freight dovetail jig - Router Forums
post #1 of 4 (permalink) Old 05-18-2016, 12:03 PM Thread Starter
Default Harbor Freight dovetail jig
I picked up the HF jig and found the better instructions and how-to videos online. But I'm confused as the side stops for the vertical board extend above the horizontal level of the flat top by about 3/16". So the horizontal board either sits on top of the vertical side stop or is stuck behind it (see pic). These parts seem like stamped metal so I doubt the are the wrong size. I did notice a couple parts were assembled wrong by HF, so wondering if this is he case again or if I'm doing something wrong.
Matt
mattmeitzner is offline
post #2 of 4 (permalink) Old 05-18-2016, 01:20 PM
vchiarelli's Avatar
First Name: Vince
Matt:
That jig is probably a blind dovetail jig only so you would route both pieces (vertical and horizontal) at once.
I can't tell how those stops are attached from the picture but they are generally adjustable, so they may have been installed incorrectly.
However, when you set the vertical piece in place, the horizontal piece will butt up against the back of the vertical piece so the horizontal piece will/ should not be affected by the stop.
vchiarelli is offline
post #3 of 4 (permalink) Old 05-18-2016, 04:57 PM Thread Starter
Bingo. I was trying to set up the horizontal piece first and now that I look at the pics, you're spot on. Thanks
post #4 of 4 (permalink) Old 05-18-2016, 05:45 PM
vchiarelli's Avatar
First Name: Vince
Not sure which video instructions you saw online but this one is pretty good. The Craftex is probably very similar to the jig you have. The presenter, Mark Eaton is a regular presenter for Kreg products as well. I've seen him in person at woodworking shows in my area. Enjoy
Dovetail jig setup block? Goblu Jigs and Fixtures 2 06-27-2014 06:52 AM
custom made dovetail jig? Jack Wilson Jigs and Fixtures 18 03-23-2011 07:57 AM
My Dovetail Jig Arrived.... challagan Jigs and Fixtures 21 01-08-2007 05:52 PM
Sliding DoveTail Jig bobj3 Jigs and Fixtures 5 01-06-2007 08:31 PM
DoveTail Jig for the Router Table bobj3 Jigs and Fixtures 32 11-30-2006 04:02 PM
