Jig Materials Question - Router Forums
 19Likes
post #1 of 19 (permalink) Old 05-23-2016, 05:34 PM Thread Starter
Contributor of the Month
Default Jig Materials Question
How do you decide what material to use to make your jigs? I realize that in some cases only one material will work whereas there are no other materials that will. When there is a situation where there is more than one viable material option what goes into your choice of material decision making process?
Just curious.
JIMMIEM is offline
post #2 of 19 (permalink) Old 05-23-2016, 05:41 PM
TwoSkies57's Avatar
If its a one off, or a wham bammer, I'll use MDF...If its something I think I'll keep and get alot of use out of, I'll go with a good baltic birch..I've also done a few common angles in 1/4" plastic for inlays...
Herb Stoops likes this.
Skipper the Penguin
TwoSkies57 is offline
post #3 of 19 (permalink) Old 05-23-2016, 06:05 PM
baltic birch...
Stick486 is offline
post #4 of 19 (permalink) Old 05-23-2016, 06:07 PM
Most of my jigs are for a one-of so what ever shop scraps I have, quite often mdf or particle board. For something that will be around for a while I use plywood.
post #5 of 19 (permalink) Old 05-23-2016, 10:01 PM
Ghidrah's Avatar
First Name: Ronald
I'm with Charles, the vast majority of the things I make are 1.O.A.K. 90% of the jigs are 1/4" luan the rest are 1/4" hard board. I prefer the finish cut properties of luan over HB which seems to get fuzzy and for whatever reason I seem to have more difficulty tracking the pattern cutout on HB.
Ghidrah is offline
post #6 of 19 (permalink) Old 05-23-2016, 11:46 PM
RainMan 2.0's Avatar
Mdf for me
cocobolo1 likes this.
Ok ,I never insulate
RainMan 2.0 is online now
post #7 of 19 (permalink) Old 05-23-2016, 11:46 PM
MT Stringer's Avatar
Anything within my reach is game!
MT Stringer is offline
post #8 of 19 (permalink) Old 05-24-2016, 12:37 AM
Jim, it really depends on the project. I use 1/4" Masonite(tempered hardboard) for most of my templates. A production template needs to be built of sturdier material. I designed this rail system for one of the forum members so he could mass produce clock bodies. There are individual sleds that ride on the rails with different patterns cut in them. Each sled is designed to work with specific guide bushings and router bits. (There are more than the three sleds shown) The sleds are located in different positions using the key to lock them in place. After sled 1 has been used in each position sled 2 replaces it and so on. This greatly reduces bit changes and speeds the process.
I only designed this system, Ron did the layout and build; he did a great job! The last two photos show the finished product. The bench top shown is actually part of the jig; more materials here than a typical template but it is all the same idea.
post #9 of 19 (permalink) Old 05-24-2016, 12:49 AM
Here are a couple templates that Barb used for her leaning wine bottle holders. The hole template worked fine but the routing template(with the toggle clamp) flexed; this should of had 1/2" plywood for the bottom.(My bad)
Name:	Wine holders.jpg
post #10 of 19 (permalink) Old 05-24-2016, 06:57 AM
difalkner's Avatar
First Name: David
Fixtures with moving parts, like my pantograph or guitar side bender, Baltic Birch. For templates I use MDF, Masonite, Plexiglas, or if it's a one-time then whatever pieces fits will work.
David
Curly Wood Shop on Etsy
Romans 3:23
difalkner is offline
Kreg jig question greg.l Tools and Woodworking 17 11-16-2014 11:36 AM
Yet another dovetail jig question drbbob Jigs and Fixtures 1 01-27-2012 10:20 AM
Oak Park Box Jig question gazippoman Jigs and Fixtures 4 04-08-2009 04:17 AM
Question about Jet Dovetail Jig kalida309 Jigs and Fixtures 5 02-16-2009 06:12 AM
Router Biscuit Bit Usage Question (jig)??? Nickbee Router Bits - Types and Usage 15 11-22-2007 11:55 PM
