Router sled?? - Router Forums
 19Likes
post #1 of 18 (permalink) Old 05-29-2016, 05:58 AM Thread Starter
First Name: Pat
Default Router sled??
Good morning guys, I was reading thru some older threads and came across one about whether to add a miter slot. I don't have one on my table and have not needed it or maybe I did and didn't know it.
I read there was a sled made to reference off the table fence instead of riding in the track. I would like to see any styles that you've made and any speciality ones for a specific task. I really need something to work on smaller parts, right now I just use a wooden clamp to hold them.
Belg is offline
post #2 of 18 (permalink) Old 05-29-2016, 08:13 AM
schnewj's Avatar
As always there are several schools of thought! Personally, I have a slot on my table and never used it. I find that it it much easier to reference off of the fence. It works for me, but others may prefer to do things differently.
Think what you are most likely to do. Will you have a repetitive need for a dedicated sled that references off of a miter slot? Certainly, having a slot and not needing it is a lot better then needing one and not having it.
Bottom line it's a personal choice.
jj777746 likes this.
schnewj is offline
post #3 of 18 (permalink) Old 05-29-2016, 08:21 AM
First Name: Richard
I think Bill said it very well. I don't have a miter slot and reference off the fence but if you think you will use the slot then by all means add one. I had a table once that had a slot but I never used it. Lots of things in woodworking come down to what works for you.
Shop guy is offline
post #4 of 18 (permalink) Old 05-29-2016, 09:00 AM
Honored Member
First Name: pat
" I would like to see any styles that you've made and any speciality ones for a specific task. "
The sled (with 3 toggles) is on its own track, definitely a hybrid.
The cutter (under the plastic hood), is, of course, colleted to a router under the aluminum rectangle. That affair is captured on its own dovetailed (45° ) slides and keys (phenolic).
So the sled slides independent of the motor slide.
The sled will securely hold stock from ~1" x 1" to ~12" x 25", essentially any thickness.
Might be an idea there for you.
Routers.
Quillman is offline
post #5 of 18 (permalink) Old 05-29-2016, 09:07 AM
I don't use a sled I just use a square push block and if you watch some of the pro's videos like Marc Sommerfeld he does the same. Some members do use the miter slot for mitering and some just like to have it so they can use feather boards with it.
post #6 of 18 (permalink) Old 05-30-2016, 05:02 PM
As far as I know Bob Rosendahl's "Mortise and Tenon System" featured the first router sled commercially available. Other companies have offered their own versions with different clamping solutions. These photos are snipped from one of the Router Workshop E-plans from Oak Park.
You can learn a lot from these E-plans.
Name:	M and T system.JPG
post #7 of 18 (permalink) Old 05-30-2016, 05:41 PM
hawkeye10's Avatar
First Name: Don
I only use my slot for a feather board but I found out many years ago I don't know it all.
Herb Stoops likes this.
Don in Murfreesboro,Tn.
hawkeye10 is offline
post #8 of 18 (permalink) Old 05-30-2016, 06:13 PM
I agree with Don, The T-slots work great for the Jessem feather boards
they can be set in any place across the table,. And the t-slots in the fence the same. also are good for setting stops.
I have never thought of a sled on the router table as the thickness of the bottom takes away from the height adjustment on the bit. I use a block to keep the piece square with the fence a pusher, and a backer board all in one.
I suppose a guide rail could be installed on the push block to run in the t-track, Hmmmm... you would have to make sure the fence was parallel to the t-track.
Herb Stoops is offline
post #9 of 18 (permalink) Old 05-30-2016, 07:27 PM
That's the problem with using a t track and the fence. Not only does the fence have to be parallel to the t track but you also have to get the right amount of bit exposed too which makes doing it that way time consuming and frustrating. Most of us are doing woodworking for fun so eliminating the frustrations and keeping it simple is usually the best way to go.
post #10 of 18 (permalink) Old 06-01-2016, 11:34 AM
To me, the slot's main use is holding featherboards. I do have a small sled meant to hold rails, but it never gets used, instead, I just use a square of MDF with a handle attached as a push block Much easier, and I use Sommerfeld matched bit sets so everything is cut face down so the plate becomes the reference point. I have a split fence, and they are not perfectly aligned, so I have put some paper shims behind the low side.
DIY Router Planing Sled huckyourmeat Jigs and Fixtures 19 03-11-2013 10:59 AM
A DIFFERENT ROUTER LATHE or “A ROUTER STANDARDIZER” neville9999 Jigs and Fixtures 8 01-04-2013 12:48 PM
Using Your Router For The First Time learnexperience General Routing 0 07-23-2011 09:20 PM
Using Bill Hylton's router sled loninappleton Jigs and Fixtures 0 02-20-2009 11:04 PM
