Spline within a spline - Router Forums
 8Likes
  • 3 Post By chessnut2
  • 4 Post By Quillman
  • 1 Post By Cherryville Chuck
post #1 of 10 (permalink) Old 08-11-2016, 04:19 PM Thread Starter
chessnut2's Avatar
Default Spline within a spline
Jack Houweling posted this design for a jig to make a unique spline joint:
TenGees, Nickp and Bushwhacker like this.
chessnut2 is offline
post #2 of 10 (permalink) Old 08-11-2016, 05:12 PM
hawkeye10's Avatar
First Name: Don
Thanks Jim that is a great video. I watch a lot of his stuff.
PS- Sometimes I wonder if any one on YT makes anything out of lumber that isn't scrap.
Don in Murfreesboro,Tn.
hawkeye10 is offline
post #3 of 10 (permalink) Old 08-11-2016, 05:22 PM
Honored Member
First Name: pat
Did something similar with a glue-joint cutter I designed.
chessnut2, TenGees, Nickp and 1 others like this.
Quillman is offline
post #4 of 10 (permalink) Old 08-11-2016, 06:22 PM
hawkeye10's Avatar
First Name: Don
Pat that is what I call real nice.
post #5 of 10 (permalink) Old 08-11-2016, 07:46 PM
First Name: Richard
Nice!
Shop guy is offline
post #6 of 10 (permalink) Old 08-11-2016, 08:04 PM
Gaffboat's Avatar
First Name: Oliver
Nifty technique, Jim. Thanks for the video link.
Gaffboat is offline
post #7 of 10 (permalink) Old 08-11-2016, 10:56 PM Thread Starter
chessnut2's Avatar
Whoa! That's nice! Tell me more!
post #8 of 10 (permalink) Old 08-12-2016, 01:26 AM
Pretty impressive Pat.
In the OP, if you look at the light colored major spline with the dark minor spline, first, it looks off balance. Second you can see the joint between the light spline and the light colored box. In the second example with the dark major spline and the light colored minor spline the dark wood hides the joint between it and the box. In the first example the shadow line of the joint is clearly visible. In the second example the dark wood hides the shadow line. For some reason the subject of shadow lines and how to use them or avoid them as necessary receives very little attention in woodworking but it is something that can make a huge difference in how something looks.
Nickp likes this.
post #9 of 10 (permalink) Old 08-12-2016, 05:02 PM
Bushwhacker's Avatar
First Name: David
Default A spline within a spline
https://www.youtube.com/watch?v=ej94...em-uploademail
That is a very cool gig you made. I plan to note it on Utube so I can make one of my own. Very nice idea. Thanks
David
When the enemy is in range, so are you.
Bushwhacker is offline
post #10 of 10 (permalink) Old 08-13-2016, 10:14 AM
Honored Member
First Name: pat
"Whoa! That's nice! Tell me more!"
Conceptually trivial, practically not so easy.
This was an experiment done > 20 years ago.
The upright spire, tapered with saw & router, is then glue jointed. (Glue joint cutter design still proprietary).
Then random width (equal thickness) of Padauk glue-jointed (routed) and glued in place. Next, the padauk was wasted at ~ the same angle with saw leaving ~1/2" of stock. Then glue-jointed again. The cutter wastes about .25" so the result = ~.25 of squiggly line.
Next the seat rails are glued to the spire and shaped.
The seat is glue jointed & doweled to the end assemblies.
That keeps the whole thing together. And since the seat rails are relatively short, the things lives on without breaking, in spite of the x-grain assembly.
2 more examples in the stack of joints. Second from bottom, & second from top. With straight line work, the procedure is really trivial.
Quillman is offline
Details and pix of spline jig DesertRatTom Project Plans and How To 9 06-19-2016 08:48 AM
How do I size a spline Sparks Portable Routing 5 09-09-2010 11:11 PM
Spline vs. Tongue & groove wanart General Routing 1 02-28-2006 07:22 AM
Slot Cutter or Spline cutter kimbert General Routing 3 10-20-2005 07:26 PM
dovetail spline joints reible Jigs and Fixtures 7 10-02-2004 02:50 PM
